Old 12-02-2010, 02:40 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Adding battery compartments and doors
I am again contemplating the paucity of battery capacity in my traylah.
I have the two forward-facing battery compartments, each with a flooded cell, Group 27, deep cycle battery. This is the largest battery that will fit.
I'm thinking of adding two additional forward-facing battery compartments with individual doors. There seems to be enough room though the subwoofer may have to be moved.
Has anyone done this?
Old 12-02-2010, 03:01 PM   #2
1986 25' Sovereign
Plant City , Florida
Jammer,
My trailer only came with one battery cave, at some point my grand father had an identical one added to the other side. Since taking ownership I have thought about adding a third and fourth battery at an angle off the first box.
See the attached image
ck21084 is offline   Reply With Quote
Old 12-02-2010, 04:27 PM   #3
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
I also am comtemplating additional battery capacity. I currently have the single battery compartment. Rather than add a second, and a third and a fourth, my thinking is to have a single 8D Lifeline AGM right in the middle. Venting (tho not needed) will be easy. I will have to relocate the crappy univolt which I am replacing anyways. In my 78 Tradewind there seems to be just enough (and I mean just enough) room for this.
Tongue weight will go up in the range of 60 pounds since I remove a battery and the old vacuum hydraulic brake actuator.
I currently have a Lifeline 8D in my 67 safari, it has worked out great.
John H
johnhh is offline   Reply With Quote
Old 12-02-2010, 04:48 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
John that is an alternative I am considering as well.
Due to the problems posed by mixing AGM and flooded types it would be necessary for me to replace the two existing batteries with AGMs if I plan to continue using them.
Bottom line the AGM batteries cost $2.50 an amp hour while flooded batteries cost $1.50 an amp hour. This is a recurring cost. For a 500 AH battery string this is a $500 cost difference every five years. It is for this reason that I am exploring the possibility of adding compartments, or, to ck's point, expanding the existing ones.
Adding a Second Battery davesid 2002 Safari 6 12-15-2014 03:16 PM
Adding Battery? Roadrunner Batteries, Univolts, Converters & Inverters 1 10-19-2009 09:24 PM
Adding a Second Battery Jfuller678 Batteries, Univolts, Converters & Inverters 15 04-01-2009 11:08 PM
Adding a battery (or two) DocBear Electrical - Systems, Generators, Batteries & Solar 2 03-30-2006 09:15 PM
Battery weeping outa the compartments Kistler Our Community 4 06-16-2003 09:39 PM
