Old 05-19-2017, 05:50 AM   #1
2016 30' International
redondo beach , California
Adding a Third AGM
Our trailer has two stock AGM batteries charged with a Boondocker 12/60 and two stock 80W solar panels.
Inside the trailer under a couch is an almost empty space except for an inverter laying loose on the floor. ( No screws, an Airstream custom installation. )
Of course there are some fat 12V cables going to the inverter.
Why can't I just add a third AGM battery there in that empty space? I've got the 12V there and it would just put a third battery in parallel with other two.
Randy and Beth
2015 F250 Titan 50 gallon tank
2016 International ProPride, EasyStart, Michelin 16", Battle Born LiFePO4 x 2, PD 60 Amp converters x 2, Victron BMV 712, Orion 12/12, and Blue Solar MPPT all in a rolling experiment
Nobody's perfect and I'm a perfect example
mythbuster88 is offline   Reply With Quote
Old 05-19-2017, 06:21 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I don't know why not. Airstream does undersize all of their battery cables but you would be no worse off than you already are. Just beware that you will not get equal charging from your charger, but I doubt that results in the loss of many amp-hours. By the book, batteries should be replaced at the same time and a battery monitor is not going to tell what is going on with one of 3 batteries in parallel. Again, that may not be a significant issue.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-22-2017, 05:49 PM   #3
Ayr , Ontario
Go for it
gator.bigfoot is offline   Reply With Quote
Old 11-26-2017, 06:17 PM   #4
2018 27' International
Coopersburg , Pennsylvania
This sounds like a great idea.
Did you end up doing it? If so, how did it work out?
BillF95 is offline   Reply With Quote
Old 11-26-2017, 06:32 PM   #5
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
I'll post about it. I did it in March '17. I added a third AGM battery class 31 under my sofa as I too had a space next to the inverter. It added a nice amount of reserve to the solar mix. Everything good so far. I ended up with one of those Duracell batteries from Sams with a connector that can be disconnected by a twist.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 11-27-2017, 05:21 AM   #6
You beat me to it!
Randy and Beth
Old 11-27-2017, 05:34 AM   #7
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
As Larry said you want to match your batteries which usually means replacing them all at the same time. But since your trailer is relatively new you might get away with just getting the same model battery as the other two (Lifeline AGMs ?). Consider upgrading your battery cables and rerouting the cables to work better at the same time, there are several posts about how to do that. Some local battery stores will make custom battery cables or you can purchase them online.--Frank
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Adding Third TV for front passenger Harleydeal Sprinter and B-van Forum 12 08-06-2015 06:52 AM
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 06:35 PM
Adding a third brake light to a vintage trailer Journalist Lights - Interior & Exterior 7 07-06-2010 10:18 PM
Cooked THIRD 700R-4 GM Suburban Transmission. Andrew M. Franklin Tow Vehicles 38 12-21-2005 11:19 AM
third axle bent patrick mckenzie Airstream Motorhome Forums 3 06-23-2003 06:32 AM
