Old 11-09-2010, 05:12 PM   #1
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
adding a second battery
I plan to add a second battery with a marine switch. (off - 1 - 2 - both)
I plan to use one at a time when camping.
My question is, when towing is it ok to charge both at the same time or one at a time?
GeocamperAS is offline   Reply With Quote
Old 11-09-2010, 07:01 PM   #2
SteveH's Avatar
Common Sense , Texas
Technically, it will work either way. But, with the two in parallel, they won't get much of a charge because it will be devided between the two, and with the resistance in the wire from the front of the tow vehicle back added in, it's even worse.
So, it would be better to charge one, and then the other assuming you have far enough to drive.
Regards,
Steve
Old 11-10-2010, 06:07 AM   #3
1974 Argosy 28
Images: 37
Do newer AS have two batteries? Do they use a switch? Or is there a better way of adding a second battery?
Old 11-10-2010, 07:06 AM   #4
SteveH's Avatar
Most newer Airstreams have two batteries and they don't get much of a charge when driving.
Regards,
Steve
Old 11-10-2010, 08:22 AM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
get a quiet generator!
Another caution when using two [lead-acid] batteries: if they are used in parallel, their must be very closely matched. You cannot use an older battery with a newer one--the new one will very rapidly deteriorate to the condition of the old one.
If you have two new batteries and charge (or discharge) them separately, you have to keep very careful track of the charge and discharge cycles if you intend to parallel them at other times. If they get out of whack, they both head south.
My recommendation is start with two new batteries and keep them in parallel all the time. This sort of defeats a possible benefit of using one at a time, where you get a heads up when you've used half your juice, but I guarantee you will quickly ruin the batteries if you sometimes use them separately and sometimes in parallel. It's just too hard to keep up with them.
I've added a second battery to two of my Airstreams and then a year or two later got rid of the second one and got a Honda 2000i instead. You will be far ahead of the game to have a single battery [that's good for 2-4 days] and a generator, than having two batteries to get you through a week. Plus, you'll be able to run a microwave! The weight of a second battery is also a problem, especially if you have a longer Airstream. Put the generator in the back of the tow vehicle.
Zep
Old 11-10-2010, 11:07 AM   #6
1974 Argosy 28
Images: 37
I would be concerned that a generator would be to loud and get other campers mad at me.
Adding Battery? Roadrunner Batteries, Univolts, Converters & Inverters 1 10-19-2009 09:24 PM
adding battery bikeguy Batteries, Univolts, Converters & Inverters 4 07-07-2008 11:42 PM
Help - Adding Battery Mookie Electrical - Systems, Generators, Batteries & Solar 3 04-10-2006 05:32 PM
Adding a battery (or two) DocBear Electrical - Systems, Generators, Batteries & Solar 2 03-30-2006 09:15 PM
Adding a second battery... drboyd Electrical - Systems, Generators, Batteries & Solar 3 07-28-2003 01:45 PM
