Old 04-01-2009, 09:46 PM   #15
4slice
4slice's Avatar
1977 31' Sovereign
Chase , British Columbia
Similar to "jfuller678", I've been thinking about adding batteries to the A-frame. I would like to go with four golf cart batteries in a custom built aluminum box mounted between the tanks and the front wall. This will mean building a new mount system for the tanks, and they will sit about one-and-a-half inches higher, and two inches forward of their present position. My concern is the added weight of the batteries--the F250 can handle the extra tongue weight, but can the A-frame take the load? I would love to hear others' experiences with this.
Gary
"4slice"
77 31'
4slice is offline   Reply With Quote
Old 04-01-2009, 10:08 PM   #16
1972 Travelux Princess 25
Cobourg , Ontario
Is there a wire in your hitch wiring harness that goes to your trailer battery? You could tap into that to connect your batteries. Then ground the - to the trailer frame.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Adding a Second Battery davesid 2002 Safari 6 12-15-2014 02:16 PM
adding battery bikeguy Batteries, Univolts, Converters & Inverters 4 07-07-2008 10:42 PM
Help - Adding Battery Mookie Electrical - Systems, Generators, Batteries & Solar 3 04-10-2006 04:32 PM
Adding a battery (or two) DocBear Electrical - Systems, Generators, Batteries & Solar 2 03-30-2006 08:15 PM
Adding a second battery... drboyd Electrical - Systems, Generators, Batteries & Solar 3 07-28-2003 12:45 PM
