Old 04-19-2010, 04:48 AM   #1
lascassas_camper
Apache_Camp's Avatar
1975 Argosy 24
Gatlinburg , Tennessee
Adding a battery to our Palamino Popup
Hey guys, I know its not an Airstream, but we bought a 1995 Palamino Mustang Popup Camper to go along with our Argosy-Airstream and it does not have a seperate battery.
The Popup has 110/115 volt shore power with a power converter, I want to add a 12 volt battery, probably to the tongue area.
*1975 Argosy-Airstream 24
*1995 Palamino Mustang Popup Camper
*1996 Buick RM Wagon 5.7L V8, AT/OD, tow pkge, coil over shocks, hitch, brake box, cooler.
*Good Sam Club Life Member
Apache_Camp is offline   Reply With Quote
Old 04-19-2010, 06:44 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Here is a good basic wiring diagram for your conversion. http://www.vintagetrailersupply.com/...ingdiagram.jpg
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-19-2010, 06:55 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Apache camp,
Dig around and see if there is any pre-existing wiring for the 12volt system. Most popups I have dealt with had some sort of wiring for the battery, quite often led out to the tongue for battery installation. Typically it will be a black and white two strand wire.
Aaron
WBCCI #XXXX AIR #2495
Old 04-22-2010, 08:02 PM   #4
lascassas_camper
1975 Argosy 24
I noticed today the "Converter" has a switch for "Conv/Off/Batt, so I'm guessing it had or had an option for a battery, I also saw a black and white wire coming out of the converter but it went into hidden areas.
I'm assuming this Converter just converts 110volt shore power to 12 volt power for the lights......I don't see a 12 volt fuse block, should I add a fuse block and will this converter work??????
Old 04-22-2010, 08:33 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The converter should have either an internal fuse block, or a breaker panel behind it. I'm installing a battery in a Coleman popup at work that never had a battery, and most of the stuff it needs is already there.
You'll need a group 24 deep cycle battery, a battery box for it to go in, about 5 feet of relatively thin angle iron to weld to the tongue for support, and a pigtail assembly to hook the battery to the popup's electrical system. I'll take my camera to work tomorrow, and see if I can document the upgrade for you. If I can get to it, I'm kind of covered up in work right now...
Adding a Second Battery davesid 2002 Safari 6 12-15-2014 02:16 PM
Adding Battery? Roadrunner Batteries, Univolts, Converters & Inverters 1 10-19-2009 08:24 PM
adding battery bikeguy Batteries, Univolts, Converters & Inverters 4 07-07-2008 10:42 PM
Adding a battery (or two) DocBear Electrical - Systems, Generators, Batteries & Solar 2 03-30-2006 08:15 PM
adding popup to the family tandemfish General Motorhome Topics 8 05-26-2005 08:03 PM
