Old 12-10-2012, 04:15 PM   #1
Santa Barbara , California
Adding 12V to '57 Caravanner
I'm in need of some advice...
I'm replacing my old AC fridge with a dometic 2-way which requires 12v to operate. I have a 7 prong pigtail which provides an isolated 12v to a single light fixture and a 12v outlet plug, which i can tap into and will work when my truck is hooked up to the trailer. What I need is a simple design for when I'm
hooked up to AC power and also when boondocking. I'm sure this has probably been answered here somewhere...and I've been looking for a few hours; but can't find the answer yet. Any pointers would be appreciated.
Alumillenium is offline   Reply With Quote
Old 12-10-2012, 05:27 PM   #2
1958 26' Overlander
Lander , Wyoming
What is your battery status? That's your source of 12V while boondocking. To get the AC power to charge your battery while plugged in you will want to get a modern converter/charger installed. Nice carravanner you have there! Ed
n2batr is offline   Reply With Quote
Old 12-10-2012, 05:48 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Be careful! You could end up with a drained tow vehicle battery. A self contained battery with high Amp Hours .....and a newer type converter for those times when you have plug in capability.....thats what you need.
Old 12-10-2012, 06:54 PM   #4
1971 27' Overlander
2004 25' Safari
Jourdanton , Texas
A good point to start on understanding what you need is The 12volt Side of Life (Part 1). There is a Part II that is linked at the end of Part I. Give a lot of thought to what you want to power beyond the refrigerator. Getting it right the first time will save you money.
Read through one of the Caravanner or Flying Cloud threads from the mid fifties to see what others have done.
Prickly Pear is offline   Reply With Quote
12v
IDEA for a Refrigerator install with a 12v & solar fan BB 55 Bubble Refrigerators 12 01-30-2012 11:17 AM
Best 12V Dehumidifier palmer51 Winterizing, Storage, Carports & Covers 1 11-04-2011 10:33 AM
Caravanner :: 1957 Airstream Caravanner floyds1 Airstream Registry Discussions 0 08-19-2011 08:32 AM
'57 Caravanner Island Girl :: 1957 Airstream Caravanner pbearsailor Airstream Registry Discussions 0 08-19-2011 08:30 AM
Adding a second battery Kimball Electrical - Systems, Generators, Batteries & Solar 1 05-15-2011 12:27 PM
