Originally Posted by doughpat
Hi all-
Trying to install a wildkat pd4655 and can’t tell if I’ve lost the adaptor or if it wasn’t included. It appears to be a plastic rectangle that mounts below the actual converter.
The wiring looks very straightforward, it’s just securing the thing that seems to be causing me grief.
Has anyone installed one from bestconverter.com? I had assumed that any adapter would be included...looks like a 59 cent part.
I just installed a PD4655 Wildcat in my 2018 27' Globetrotter. I got a pendant with mine, but it may have been an option. If it was supposed to be included, Randy will send you out one immediately if you contact him. My first PD4655 with Pendant installed in my 2017 Flying Cloud had a pendant problem and Randy immediately shipped me a replacement.
Securing my PD4655 was done by installing a plastic bar about 6" long below the unit. Then the PD4655 slid into that plastic bar and snapped into place.
Be careful with the wiring. The wires on the stock converter do not criss-cross. The
12V and 120V wires on the PD4655 needed to criss-cross on both of my installations. I know others have fried their PD4655's by connecting the
12V wires to the 120V input.
I liked my first PD4655 so much that I bought another to replace the "advertised" multi-stage stock converter in my 2018. A PD4655 is a true multi-stage converter. My PD4655 bulks to 14.2V, then absorption at 13.6V until low amps, then floats at 13.2V. My 2018 stock converter only bulked to 13.6V, absorption at 13.6V to low amps, then float at 13.2V. The stock "multi-stage" converter could not recharge my batteries in a reasonable amount of time at 13.6V so I installed a PD4655 that charges at 14.2V. At 14.2V, the PD4655 can bring your batteries up to 90% charged in 3 to 6 hours with a generator.
https://www.progressivedyn.com/rv/po...#charge-wizard The stock multi-stage converter at 13.6V took at least twice as long to get out of bulk (90% charged), which was way too long for charging with a generator.
Good luck with your installation.
