Old 06-11-2014, 01:53 PM   #15
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
Are the intelligent converters considered the 3 stage converters? And the Univolt is the Inverter?
I cannot thank you enough!!!
Rhino33 is offline   Reply With Quote
Old 06-11-2014, 02:51 PM   #16
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
A "converter" is the gadget that takes in 120 volt alternating current and puts out 12 volt (yeah, more or less, I know) direct current to charge your coach battery. An "inverter" does just the opposite - it takes in 12 volts direct current and puts out 120 volts alternating current so you can run the blender.
And yes, the "intelligent" converters are three-stage. Check out this page for more than you ever wanted to know about converters.
adapter, battery, cable
Battery Cable Too Short PJohnson Batteries, Univolts, Converters & Inverters 15 04-27-2013 08:59 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Battery cable gauge Robin Stone Batteries, Univolts, Converters & Inverters 5 03-04-2008 07:52 PM
Spedo cable adapter. SebastianD Airstream Motorhome Forums 1 09-14-2003 06:07 PM
