Old 11-03-2010, 07:16 PM   #1
uncledan's Avatar
1966 17' Caravel
College Station , Texas
Adapter
I have an adapter queation. We just got a 66 Caravel and would like to plug it in. No having a out let that matches the trailer plug I'm looking at 15a/30a adapter. The web site says it's OK to charge the battery but there is a warning that it is dangerous to draw more than 15 amps from a 15 amp outlet.
Does anyone have any advise as to what I should avoid doing to stay with in the 15 amp limit?
Also my trailer plug appears to be missing what I'm assuming is the grounding prong.
Do I need to replace the plug or can I fix it?
uncledan is offline   Reply With Quote
Old 11-03-2010, 07:33 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would definitely replace the plug or go for a new cable with a molded plug.
Don't try and run the Air Conditioner with the 15 amp adapter. That should be the only big draw item in your trailer.
Richard
azflycaster is online now   Reply With Quote
Old 11-03-2010, 07:37 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
That plug has to be replaced NOW. That is the ground terminal and without it the trailer is FLOATING and any problem will result in 120 trailer to ground which may be you standing outside.
I don't generally get excited with a lot of the precautions that are posted here but this one warrants attention before you go any further.
2004 Excursion 4x4
Old 11-03-2010, 08:08 PM   #4
uncledan's Avatar
1966 17' Caravel
Thanks for the warning. Currenly just using the battery. I won't plug it in untill I find a plug replacement. Will start looking for one.
Thanks again
Old 11-03-2010, 08:46 PM   #5
HowieE's Avatar
Images: 12
In the mean time just use a battery charger plugged into the house to keep the battery up.
2004 Excursion 4x4
Old 11-03-2010, 08:56 PM   #6
Kevin245's Avatar
I'm a fan of the molded end cables but you most certainly can replace the plug and reuse cable if it is still serviceable. The plug you'll need a NEMA TT-30P.
Good luck,
Kevin
Eleanor Roosevelt
New '69, 110 adapter too much for AC? stowaways General Repair Forum 2 06-26-2009 01:52 PM
'76 TV adapter Chip Arnold Audio, Video & TV 15 08-05-2008 07:23 AM
new shower adapter? kiltchick84 Sinks, Showers & Toilets 2 07-01-2008 02:39 PM
4 to 7 pin adapter ? Dan S Towing, Tow Vehicles & Hitches 24 03-10-2007 07:01 PM
Adapter Daisy2 Electrical - Systems, Generators, Batteries & Solar 7 03-24-2006 07:51 AM
