Old 03-09-2009, 06:14 AM   #1
Denis4x4's Avatar
Durango , Colorado
Accessing Shore Power Plug on '06 Safari
I have an '06 Safari 25' FB and due to stupidity on my part, the shore power plug has been fried. My question is how to access the inside wiring to replace it. At first glance, dropping a corner of the belly pan might get the job done. Removing the corner plastic housing looks like more trouble than I want to tackle.
Any thoughts, hints or ideas?
Denis4x4 is offline   Reply With Quote
Old 03-09-2009, 06:16 AM   #2
Why bother with the cable?
You can replace just the plug.
Old 03-09-2009, 07:15 AM   #3
Denis4x4's Avatar
Durango , Colorado
The male plug on the trailer needs to be replaced. No problem replacing the power cord female plug
Old 03-09-2009, 09:10 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
On our 2004, I believe that the connector that you are talking about is above the floorboard and may not be accessible from the belly. Of course you unit is different than mine. IIRC, my outside connector is screwed into the body. I would assume if yours is similar, you could simply unscrew it, remove it and install a new one?
Old 03-09-2009, 12:30 PM   #5
Denis4x4's Avatar
Durango , Colorado
First off, the male shore plug on the trailer is fried. It's below the floor and inaccessable from inside the trailer. There is not enough wire sticking through after the actual plug is removed from the plastic housing. I have a new plug/plastic housing and I need to install longer wires to attach to thew male plug in the plug.
Old 03-09-2009, 12:33 PM   #6
Aluminut
2004 25' Safari
. , Illinois
As I said, my unit is different than yours, but it sounds to me like you have it under control. Sorry for the post.....
Shore Power Again The Flintstones Batteries, Univolts, Converters & Inverters 13 10-09-2007 07:18 PM
50 and 30 amp shore power tinbender Electrical - Systems, Generators, Batteries & Solar 15 06-22-2007 10:33 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
Shore power cord FreshAir Electrical - Systems, Generators, Batteries & Solar 18 02-21-2007 02:41 PM
Power w/o batt. just shore... crazylev On The Road... 8 11-12-2004 04:14 PM
