Old 07-03-2013, 04:40 PM   #1
1975 25' Tradewind
Susanville , California
Access to Univolt on '75 25 ft Tradewind
Hi, I'm a real newbie who just bought a 1975, 25 ft trade wind and not very mechanically inclined. I immediately noticed that the battery was not being very well charged by the univolt (if not at all). I purchased a new powermax converter from best converters with all the advice I saw on this forum. I just went to the bathroom closet and opened the little port to expose the univolt. How in the world do you get it out and the new larger converter in. Hopefully, there's a plug to plug in the new con. Thanks.
bearhere is offline   Reply With Quote
Old 07-03-2013, 04:51 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums.
I think that the old Univolt is hard-wired, so you'll have to cut the wires and install a plug for the new converter. You'll probably also have to remove the base of the closet to get at the old Univolt. In case you didn't know it, the Univolt is where all the 12 volt fuses are located.
Old 07-03-2013, 06:15 PM   #3
1975 25' Tradewind
Thumbs up Thanks
I couldn't see the screws holding the cabinet floor on as the PO had put carpet over it. Once I got that off it wasn't to bad. There is a plug in the space so that is one less worry. I don't know if the factory or PO put it in although it looks original. I'll try to replace the converter in a couple days when it's cooler. Hotter than blazes right now. Does any one have any any advice on the new installation?
Old 07-03-2013, 06:38 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
My 1975 had the plug, I think it was standard that year.
I haven't gotten far enough along to give you any advice on the change out.
Aaron
WBCCI #XXXX AIR #2495
Old 07-04-2013, 02:50 PM   #5
Well Preserved
1993 21' Sovereign
Our '74 was hard wired, so the cutoff time must have been between those years.
Univolt question Stonew98 Batteries, Univolts, Converters & Inverters 11 12-19-2011 08:15 PM
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-07-2011 11:31 PM
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 11:16 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
Univolt on a 1976 Caravanner wba1 Batteries, Univolts, Converters & Inverters 12 07-27-2011 07:13 PM
