Old 01-09-2020, 08:35 AM   #1
Dkoelfgen's Avatar
2011 27' FB Flying Cloud
Albertville , Minnesota
AC Voltage Modification
Having problems with my AC Power.
How is it possible to have a lower AC voltage inside my 2011 27' FB than the 110volt AC Shore power I am hooked up to?
The voltage was reading around 68 V ac. last night after the interior lights started blinking off than on off on etc. This morning the wall sockets read 82.4 volts AC.
Could a low current supply cause this?
Does the "Converter" have the ability to modify the incoming 110 voltage?
Any help would be highly appreciated.
DK
Dkoelfgen is offline   Reply With Quote
Old 01-09-2020, 08:47 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The AC on your trailer goes through the connector on the trailer to an internal auto transfer switch, assuming you also have a connection on the front of the trailer, then to the AC distribution panel, with breakers. The converter has nothing to do with what you see at the AC outlets.
As was said to you earlier, I believe, you first need to confirm that the campground supply was truly at the right voltage and has no funny opens or grounds, which a standard plug-in tester can find.
If all is well in that regard, it is possible that you have something going on in the trailer, but that is not for a novice to be troubleshooting. AC power is deadly and I would not recommend that you do anything more than plug a voltmeter in to an outlet. If the supply is good and you are getting low voltage inside, take it to a service place.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-09-2020, 09:42 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
In general, there are two different kinds of circuits: parallel and serial.
In the parallel configuration, your incoming single line splits into several parallel lines, each of which has the same voltage as the other lines, and when you put a load on one of the parallel line, the other parallel lines remain at the same voltage. This is basically how your trailer, or any house is wired.
In a serial configuration you have a single line, and as you add loads to that line in "series" (ie., one after the other), you will see a voltage drop across each load, so that your first load sees the incoming 110V, but the second load sees only what is left over after some consumption from the first load.
So what is happening in your system is that between the shore power outlet and the breaker box distributing power (via a parralel circuit) to the outlet inside your trailer, you will effectively have a series circuit. Normally the "loads" in this series circuit are pretty negligible, but something in your system is causing a substantial load that is causing a voltage drop (incidentally, your converter should be on one of the parallel circuit branches, so should have no impact on the other parallel branches).
The absolute first thing I would do if experiencing low voltage inside the trailer is to unplug from the power post and verify that you are really getting 110V at the pole. It is not uncommon for the power posts in campgrounds to deliver lower than standard voltage. Now, if you are getting 68 v inside the trailer, but have 110V at the pole, then you have a "loss" or load in between the power pole and breaker box. Be sure also to check all of your outlets--make sure you are seeing the same voltage on all of your parallel circuits.
An obvious culprit (potential load in the series circuit) could be your shore power lead. If you were parked too far from the power post and had to use an extension that was about the same length as your basic power lead, you just doubled the resistance (load) in that part of the series circuit. This could be further aggravated if the lead or the extension are of too narrow gauge of wire, if there is corrosion on any of the male of female contacts on the extension, or corrosion in some connection inside the trailer. If you are handy with a Volt-Ohm meter, you can trace the circuit from shore power plug to breaker box, and you ought to be able to identify which compoenent is causing the drop. If you want to try something a little more quick and dirty, try just putting a hand on any (insulated) connection you can reach and see if it is warming up (don't grab any bare conductors).
good luck!
Old 01-09-2020, 09:51 AM   #4
Dkoelfgen's Avatar
Thanks, I think it has to be the Shore power, the other camp grounds were fine.
I tried plugging into the 50 Amp. (Didn't see earlier) but have the same result.
However when I plugged into the 50 Amp the voltage at the 30 Amp plug on the pedestal reads 151 volts. I then unplugged everything, on batteries and will have to move.
Thanks all for your help!
DK
motorhome air bag modification? bencbailey General Motorhome Topics 9 04-22-2005 10:12 PM
International AS Modification, table, pantry, latch,etc Pahaska General Interior Topics 9 10-03-2004 01:27 PM
CCD Modification frozen chosen Airstream Trailer Forums 0 04-07-2004 08:29 PM
Latest Modification for Tin Hut Tin Hut Exterior Restoration Forum 10 12-30-2003 09:06 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
