Old 05-31-2008, 04:08 PM   #1
Excella CM's Avatar
1978 31' Excella 500
Venice , California
A stitch in time saves mine!
While doing some general maintenance I was cleaning the interior panel of the low voltage distribution panel behind the table in the Excella. As the rag passed over the panel I noticed a flash and discovered that the panel was able to touch the main buss from the battery. Closer inspection revealed erosion from arcing where the panel corner was cut without adequate claarance and had contacted the terminal briefly on many occasions. A quick 45 degree cut with tin snips supplied the need room and made a permanent fix.
ID:	61475   Click image for larger version
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Mine glows HiHoAgRV General Appliance Topics 16 07-06-2012 01:10 PM
Anyone out there with refer as old as mine? 1959newbie Refrigerators 48 03-20-2012 06:08 PM
AS Scrapbooking & Cross-Stitch?? SilverToy Off Topic Forum 12 01-16-2008 01:14 PM
Some old Airstream Pix of mine.... commander31 Our Community 5 01-30-2007 02:22 PM
