Old 06-17-2016, 04:39 PM   #1
Victoria , British Columbia
Shore Power Troubleshooting
79 Sovereign, Canadian version (does that make a difference?)
Plugged into shore power last night, with the aircon running on low. Banged to a noisy halt, and now no univolt buzz, or A/C red indicator light on the status panel. 12 volt lights work, though.
I've got good shore power to the plug end of the shore power cable. Where to test next?
Does the SP power cable go directly to the AC panel in my trailer, or is there a connector somewhere?
After that, I'd assume that the A/C breaker panel is next - make sure the power goes that far, and that the breakers are working. (they still have a good snap to them? - and, yes, I have cycled the breakers back to 'on'!)
Anywhere further I should look, please?
Thanks!
AngusForsyth is offline   Reply With Quote
Old 06-17-2016, 08:54 PM   #2
Well, it appears that I've been running my air con on 15 amps, not 30, and so I've fried the insulation on the main power feed into the AC power panel. D'oh!
Now I just need to feed a little (6" or so) slack through, strip the new insulation away, reconnect, and I'm off to the races, minus aircon...
Old 06-18-2016, 04:37 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Huh, the lower feed should have tripped a breaker? Might want to check those out as well. But then I am not familiar with the wiring of older AS's. Good luck
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-18-2016, 05:39 AM   #4
Gainesville , Florida
Common mistake, live and learn. Good luck, hope your air isn't damaged.
Old 06-18-2016, 08:27 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
The AC may have gone off on an internal thermal overload in which case it may have saved itself.
2004 Excursion 4x4
Old 06-18-2016, 04:50 PM   #6
No worries, after I've fixed it, I'll plug it back in again, and see if it works any better next time 'round! Lol!
Bud
Well, I assume (I know...) that the breakers are fairly cheap, so while I'm in there, I'm going to replace all four of them.
Old 06-30-2016, 05:14 PM   #7
Well, got 'er sorted. New breaker went in ok, and the wires all connected, so my ac power is back in business.
But, dammit, I think I've caught a renewal disease! Thinking to replace the univolt now, and perhaps the (rusty) dc power panel...
Old 07-03-2016, 10:59 PM   #8
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Was it the GFCI breaker that went bad on you?
Old 07-04-2016, 12:20 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A/C Troubleshooting
If the wire insulation melted while running on 15 amp service something else is up.
The shore power breaker should have tripped before that happened (barring a loose connection).
#JustSayin.
Superat stultitia.
Generator troubleshooting GlenCoombe Mechanics Corner - Engines, Transmission & More... 37 08-10-2007 08:37 PM
Troubleshooting car audio system wiring? davida Audio, Video & TV 3 10-25-2006 09:13 AM
troubleshooting water pump susanborck Water Heaters, Filters & Pumps 4 07-06-2004 02:53 PM
Troubleshooting power A/C pilgrim_still Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-28-2003 07:50 PM
onan troubleshooting help rcaldwel Generators & Solar Power 2 03-10-2003 05:00 PM
