Old 10-21-2012, 01:02 PM   #1
1999 35' Cutter Diesel Bus w/slide
Puyallup , Washington
'99 Cutter battery hookup
We keep having one warm battery of the 4. Is there a diagram of the hookups for this motorhome, including where the house wires are to be attached?
Marianne
Fredmarianne is offline   Reply With Quote
Old 10-21-2012, 03:20 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
You may just have a poor connection???
This is a good read to start with.
The 12volt Side of Life (Part 1)
Maybe a picture of your present battery wiring will help us determine if it is not correct.
You have to give us a lot more detail than you have for anyone to give you a helpful answer.
There are gas and diesel pusher Cutters, which do you have?
http://www.airstream.com/files/libra...8c24bec252.pdf
Dave
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
Battery Box Modification Options Ridgerunner3 Batteries, Univolts, Converters & Inverters 5 10-09-2013 04:28 PM
What size wire for battery hookup? t7389sg Mechanics Corner - Engines, Transmission & More... 11 05-05-2011 07:51 AM
