Old 05-31-2015, 04:57 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
93 Monitor Panel
My monitor panel has 2 sides . The right side has on off toggle switches which are working. The left side has tank level and battery displays. This is not working. Troubleshooting suggestions?
Old 05-31-2015, 05:03 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Sounds normal to me.
MICHAEL
Old 06-01-2015, 12:35 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
Is there a dedicated fuse for the monitor panel?
Old 06-07-2015, 09:26 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
I find myself talking to my digital self, hopefully some one will take pity on me and answer this question before I bugger it up.
Can some one tell me how to remove the control monitor panel
Old 06-09-2015, 02:18 PM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'd like to help, but I might not have any useful information to contribute. First, some assumptions:
1. You have the same model of panel that is in our '95 - it has a couple rows of LEDs on the left for status, then there are switches for the hood light, hood fan, and water pump.
2. I assume you are hitting the test switch, and getting no response.
If both of those are true, my first thought would be that the test switch failed. I doubt it's separately fused, but if there is a fuse for it, you'd want to know why that fuse blew (possibly a short circuit).
I'm not sure how it comes out - haven't had a reason to take ours apart. But I'd start by looking under the range hood, removing the cover where the light is, and looking in there - i.e., toward the back of the control panel. An inspection mirror might help.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-09-2015, 08:07 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Do the indicator lights only come on when the test switch is turned on? Just ran out and checked. When I hit the test switch..... nothing.
Old 06-14-2015, 04:47 PM   #7
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Yes, they only work when you press and hold the test switch.
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Monitor Panel Darrell Root General Interior Topics 4 05-14-2007 07:15 PM
Monitor Panel Gareth Electrical - Systems, Generators, Batteries & Solar 8 06-25-2006 08:57 AM
345 Monitor Panel wa3vez Mechanics Corner - Engines, Transmission & More... 3 10-11-2004 04:07 PM
Monitor Control Panel ZenRVer Sprinter and B-van Forum 2 08-11-2003 10:52 AM
