Old 08-01-2015, 04:10 PM   #1
Bee Cave , Texas
9 Volts out of Univolt? Failing?
Trying to hook up a new car stereo. It wouldn't power up. Diagnosed it down to the voltage available up in the console. It's only 9 Volts. Is this a sign of a failing univolt? It have the AS plugged in, the Univolt is humming, the fuses are all fine. If I hook the stereo directly up to a 12 volt source, it works fine.
I just don't know enough about univolts to know if the 9 volt problem is due to the univolt or something else.
BluesClues is offline   Reply With Quote
Old 08-01-2015, 04:30 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Measure the voltage at the univolt. If it is 12V then the problem is somewhere else. If it is 9 volts, then the univolt may be bad. Disconnect everything from it and measure the voltage again. If 9 volts, the univolt is bad. If it is 12 volts, measure the voltage on the wires you disconnected. If 12V the univolt is bad. IF 9 volts, you have a battery or wiring problem.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-01-2015, 05:50 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Do you have a battery in the loop? If not the Uni may be toast, it likes/requires a bit of resistance.
IIWY....I'd retire it regardless, and get a modern multi, (3 or 4) stage converter.
Give Randy a call for the straight scoop
Univolt is only putting out 6.3 volts jack9443 Batteries, Univolts, Converters & Inverters 7 04-14-2015 08:23 AM
My Exhaust Fan Keeps Failing, 2012 J5MM 2011 - 2015 International 34 06-10-2014 11:01 AM
AC Thermostat failing? VeggieBullet Electrical - Systems, Generators, Batteries & Solar 6 11-27-2011 08:45 AM
AC Failing???? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 11 11-21-2011 08:39 PM
Steering Gear Leaking/Failing? swebster Mechanics Corner - Engines, Transmission & More... 6 03-19-2006 04:23 AM
