Old 02-03-2010, 09:11 PM   #1
1963 19' Globetrotter
Moline , Illinois
8 ga wire connection problem
I'm in the process of installing a new Intelli-power using the recommended 8 AWG wire and have run into a problem . The instructions call for a three way splice and I'm not sure of the best way to make that connection ,plus I can't find anything to make it with . As far as I know wire nuts don't exist for 3 # 8 wires nor do three way crimp connectors.
All I can come up with is using an automotive single stud junction block. A Bussman # JB381602 looks like it would work if I can find somebody who sells them. I'm sure others have run into this problem and there has to be an easy solution.
63air is offline   Reply With Quote
Old 02-03-2010, 09:24 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
One solution is to use three #10 ring terminal ends, then bolt them together to form a solid connection...you might then use some silicone goo to coat and insulate the connection, or some electrical tape coiled around to cover - or both...
There are probably wire nuts large enough to handle three # 8 wires, available from an electrical supply house, but you'd probably have to buy a whole box quantity...
An electrical supply house should also have a copper lug large enough for the three wires to fit inside, and has a large set screw to secure the wires together...
Twisting the stripped ends of the wires together, with a little flux and then solder is probably the best way to insure good electrical conductivity...followed up with the silicone and tape...
The possibilities are (shockingly) endless...
Ray
Ray & Pat; Morada, CA
Old 02-03-2010, 09:31 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Call for help
I am sure that Randy, at Best Converter" will help you out.
I cant figure out your three way splice. Seems to me that the converter should have a power cord in, a ground wire out and a wire out to the pos battery terminal.
Old 02-03-2010, 09:42 PM   #4
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
The silicone will corrode the copper wires just like it will aluminun.
"Humans get a lot done,not because we're smart, but because we have thumbs so we can make coffee." Flash Rosenburg
"Decaffinated coffee is the devil's blend."
GO Bob is offline   Reply With Quote
Old 02-03-2010, 09:45 PM   #5
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Yep, try a "no-ox" compound. You can get it from your local electrical supply company. Look's a little bit like grease, but will keep the bare copper from corroding.
www.nesa.org
Air No. 6427
Old 02-04-2010, 06:11 AM   #6
Moline , Illinois
I was following the schematic that VTS and Inteli-power had . I guess an acceptable alternative is to hook the converter to the battery and then hook my 12v supply line directly into the battery also so that the battery is acting as the junction block?
Old 02-04-2010, 06:21 AM   #7
2019 28' International
Leonardtown , Maryland
Solder would be my choice, but one could also go to Radio Shack and get a terminal strip with a cover and a selection of wire lugs. Put lugs on wires and mount in the terminal strip. Place the strip in a convient location. This method will make convient trouble shooting in the future.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 02-04-2010, 06:24 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Solder....
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 02-04-2010, 08:18 AM   #9
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
No Solder
Crimp! Solder will cause the wire to break just past where the solder ends. This is why the FAA does not allow solder in Airplanes. There are few exceptions. The solder creates a hard end for the wire to flex under vibration.
You can get wire nuts up the #6 or possibly larger. Marine supply places will have crimp ends in any size you want.
You plan to run to the battery then another line off the battery will work well if your battery is not on a sliding tray.
Michelle TAC MT-0
Sarah, Snowball
Old 02-04-2010, 10:04 AM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
Well you can use a split bolt. Available at hardware stores and home centers in sizes from 14 gauge to 1 gauge and larger. Cover with tape or shrink wrap....
Old 02-04-2010, 10:15 AM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
Or you can get something like this, from Affordable Solar. No tape required if you mount it inside an enclosure....
Old 02-04-2010, 10:18 AM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
Or you can get splices like these at most home centers. Again, tape and shink wrap.
Old 02-04-2010, 10:21 AM   #13
Wise Elder
Jammer's Avatar
2010 30' Classic
Or you might be able to use something like this to get the number of splices down. Available at midsouthelectronics.com, stacked electrical lugs lug splicer reducer turn prevent mechanical connectors and probably elsewhere as well.
Old 02-04-2010, 10:22 AM   #14
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
You can also use a piece copper tubing. I used copper tubing regularly when I did automotive wiring. I prefer it compared to those prefabed connectors. just wrap it up afterwords with heat shrink tubing.
arodriguez60 is offline   Reply With Quote
Cable wire connection! Archersfin Audio, Video & TV 0 09-29-2009 05:13 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Where is the tachometer connection? AccessMaster Mechanics Corner - Engines, Transmission & More... 13 06-29-2003 05:26 PM
Wi-Fi connection? Krazykraut Airstream Motorhome Forums 8 11-25-2002 11:46 AM
