Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 04-09-2009, 09:57 AM   #1
page.crow's Avatar
Profile:  1978 31' Sovereign
Jackson County , Missouri
78 Sovereign: batter recharger\transformer puzzle
Howdy Folks:
I am restoring a 78 Sovereign Land Yacht.
The battery was shot. The interior forward exhaust fan was shorted out. The previous owner pulled the fuse.
When I took ownership, I noted the transformer was cooking hot when everything was hooked up and running. The trailer is hooked up to 110v.
I suspected the transformer may be damaged. I pulled it and had it tested out. They electrician says the transformer is putting out 14v fine. I re-installed transformer and purchased a new battery.
When I plugged the unit back in, the transformer is humming loudly, like when you first hook up a battery to recharge. I checked the status panel over the stove. The panel says the battery is low\dead.
(and it's not, it's new...)
I voltage tested the two heavy cables during reinstall. I have them hooked up the right way.
I am new to this trailer. Do I disregard the status panel over the stove and live with this? I don't want to. I like all my little gizmos working good. I pulled the plug on the transformer and pulled the batter cable for now until I know I'm not heavy draining or over-charging the new battery.
Can anyone offer some suggestions what should be done next? Much obliged everyone.
<humbly bowing>
page.crow
page.crow is offline   Reply With Quote
Dometic Fridge puzzle crdouger Furnaces, Heaters, Fireplaces & Air Conditioning 9 11-19-2007 07:25 PM
Gaucho Puzzle - How many cushions?? dudebb Upholstery, Blinds, Walls & Interior Finishes 7 07-29-2007 07:42 PM
No 12Volt Power from Transformer JuliaPowell Batteries, Univolts, Converters & Inverters 4 07-09-2007 01:37 PM
Galley Puzzle Cat Cabinets, Counter Tops & Furnishings 9 10-07-2006 06:26 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
