Old 02-21-2009, 11:42 AM   #1
Mr. Decent's Avatar
1960 18' Traveler
Nomadic , Symmetry
Images: 21
'76 Converter Humm
On this '76 31' Excella I am working on, the electrical system seems to be in pretty good shape, although, I believe it is the converter? behind the kitchen counter next to the door, It has a Loud Humm, any ideas for simple solutions to lesson or get rid of the humm? Thanks for any input
Mr. Decent is offline   Reply With Quote
Old 02-21-2009, 11:47 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Buy a new converter,I think all the old ones hum.Dave
easyride is offline   Reply With Quote
Old 02-21-2009, 11:57 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ummm, Hummm, what hum? Hmmmm?
You can't beat em, join em mmmm Take up chanting. Ommmm.
All seriousness aside. The only way to get rid of the hum is to replace the Univolt. they all humm. They were OK in their day but are not effective chargers and lead to premature battery failure.
Old 02-21-2009, 01:09 PM   #4
The hum comes from the metal laminations in the transformer moving at the frequency rate of 60 cycles.
You can repot the transformer in varnish and it will stop the hum.
All transformers in power supplies, are potted, in one way or another.
Old 02-21-2009, 03:47 PM   #5
Mr. Decent's Avatar
1960 18' Traveler
Nomadic , Symmetry
Images: 21
thanks for the info, at least I know it's 'normal'
Old 02-28-2009, 12:19 PM   #6
Squid's Avatar
1979 Argosy Minuet 6.7 Metre
My old univolt hums also. Andy what does "repot" mean? I went and bought the Intlli-Power 9200. Haven't take it out of the box yet. It was alot of $. cant decide to go ahead and make the switch. the Univolt seems to work other than the hummmmmmmm. Kinda of obnoxious! To repot or not to repot, that is the question>
Squid
Captain Squid
Squid is offline   Reply With Quote
Old 02-28-2009, 03:28 PM   #7
Squid
Transformers are potted in varnish, so that the laminations cannot move.
When the laminations move, or are loose, you get the hum.
But, before you get into the repotting, sometimes just tightening the screws on the transformer will also stop the hum.
If that fails, then you can repot.
Take the transformer out of the Univolt.
Immerse it in a pot of varnish, that has a cover or lid.
Rotate the transformer to a different position, once a day, so that any air bubbles will float away.
After a week or so, you can remove the transformer from the varnish, and let it hang from a couple of the wires, so that the excess varnish drips away.
Let the varnish cure out, for a few days, so that it's as dry as it can get.
Reinstall the transformer. You will not hear the hum again.
Obviously, commercial transformer potting, is much faster.
Old 02-28-2009, 06:01 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Squid
Another consideration: The Univolts put out 13.something volts all the time when plugged into shore power. Univolts frequently overcharge batteries causing loss of electrolite and premature battery failure (battery boiling). New converters have several automatic phases and are much more battery friendly, especially for AGM batteries.
Old 02-28-2009, 07:06 PM   #9
Squid's Avatar
Thanks for the repotting insite! Think I will take the easy way out go ahead and install the 9200.
Captain Squid
Old 02-28-2009, 07:41 PM   #10
Squid's Avatar
What is a AGM Battery?
Captain Squid
Old 02-28-2009, 08:31 PM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
Intellipower upgrade
Squid,
To put in the Intellipower you will have to salvage the fuse panel from the Univolt or put in a new one. I took out the guts of my Univolt and cut off the back end of the Univolt cover and attached the Intellipower to the old Univolt base. Then wired the Intellipower leads into the old fuse panel. Here is a photo without the cover. There are other ways to do it.
An AGM is a sealed battery you don't have to add water to. That also means no sulfuric acid off gassing and no spill concerns. They cost about 3x the price of a regular flooded battery, but also last a lot longer.
If you have only the one original battery configuration you might want to consider adding a second or a larger battery. A lot of folks put in 2 6 volt golf cart type batteries wired in series to give you 12v. I put in a 12v zize 4D AGM battery which gives me 200 amp hours.
There is a lot of other information in other forum threads.
Old 03-01-2009, 11:15 AM   #12
Squid's Avatar
So AGM battery is sealed? Does that mean it is a gel-cel? The specs on the 9200 say's "For use with lead-acid and not gel-cel batteries".
I love the low maintenance of the sealed batteries. I have 3 in my boat. Don't have to do a thing except charge the trolling batteries ever so often.
Captain Squid
Old 03-01-2009, 12:23 PM   #13
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
AGMs are sealed, but are not gel celled. They still should be vented because they can out gas if they get hot.
VRLA - Wikipedia, the free encyclopedia
Richard
Old 03-01-2009, 01:15 PM   #14
Squid's Avatar
So AGM batteries, purchase your local rv store?
Captain Squid
What to do with old converter? msmst25 Batteries, Univolts, Converters & Inverters 11 06-15-2008 03:32 PM
Where's the converter? gparker Batteries, Univolts, Converters & Inverters 4 08-24-2007 03:30 AM
tv converter.. safari05-25 Audio, Video & TV 0 11-27-2006 07:10 PM
Need Some Help - converter jjohnjr Interior Restoration Forum 0 08-23-2006 06:21 PM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
