Old 12-29-2009, 06:02 PM   #15
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
I agree with Kevin as well. I'm running a deep cycle marine battery and wont change my battery configuration until I change my converter. If you dont plan on boondocking alot you wont really know any difference with shore power.
If your lights come on, that portion of the converter works and it should be fine.
...and your right about texas not requiring the brakes under 4000#, but if you go anywhere else you need to comply with that states laws as well, most are 2k, Louisiana is 3 I believe
Al
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
--Mark Twain
Alwhisman is offline   Reply With Quote
Inverter / Charger Newbie nbk3ad2 Electrical - Systems, Generators, Batteries & Solar 22 02-02-2007 09:23 AM
HF Battery Charger dmaiden Batteries, Univolts, Converters & Inverters 10 11-03-2006 11:33 AM
Inverter/Charger LRPorter Electrical - Systems, Generators, Batteries & Solar 10 02-18-2006 11:05 AM
Inverter/charger option mcneon Airstream Motorhome Forums 0 03-24-2004 05:37 PM
hummmmm from the inverter/battery charger? Anna Electrical - Systems, Generators, Batteries & Solar 5 11-25-2002 06:46 AM
