Old 07-17-2014, 02:54 PM   #1
Stork's Avatar
1976 Argosy 28
1975 31' Sovereign
1973 Argosy 24
Edmonton , Alberta
76' Argosy 28' Centre Bath Univolt help!
Okay so the previous owner installed a new converter a few years back, so I'm told...
I'm looking to replace said converter but cannot find a fuse panel, now my only question is, Where was the original fuse panel located? And where was the Univolt originally located?
Just trying to get things back the way they should be.
Thanks in advance!
Stork is offline   Reply With Quote
Old 07-17-2014, 03:40 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
In my '74 Argosy 26'. The original converter was located in the closet in the bathroom. The fuse panel was built into the original converter.
The is also a separate fuse mounted on the interior skin connected to the negative wire from the battery.
Ours is a rear bath. You might try looking on the street side rear under the bed or whatever is in that corner.
Have you located the 120 volt power panel?
Old 07-17-2014, 05:03 PM   #3
Stork's Avatar
1976 Argosy 28
1975 31' Sovereign
1973 Argosy 24
Edmonton , Alberta
That is the same as my old 24' rear bath model...
My suspicion is that the PO removed the fuse panel completely.
The Breaker Box is in the rearmost upper cabinet opposite the bathroom.
The current converter is NOT attached to any fuses....that I can find.
Old 07-17-2014, 06:52 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Typically there are at least 4 -12 volt circuits wired into the coach. Unless the PO just bundled them together and connected the bundle to a wire from the new converter. There must be a fuse block somewhere.
Do you know if all of the 12 volt fixtures and appliances work? ie the vent fans; furnace blower; water pump etc.
Can you trace the wires (2) from the converter?
Old 07-17-2014, 07:01 PM   #5
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
On my 28' 1977 center bath, the breaker box is in the night stand between the twin beds and the battery, converter and fuse panel are under the street side bed.
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 07-21-2014, 02:38 PM   #6
Stork's Avatar
1976 Argosy 28
1975 31' Sovereign
1973 Argosy 24
Edmonton , Alberta
Everything works fine, except the kitchen lamp and the refrigerator on 120...
Once I get my new converter, I'll have to rewire in a fuse panel
Why can't people just do things right, the first time?!
Old 07-21-2014, 03:01 PM   #7
Stork's Avatar
1976 Argosy 28
1975 31' Sovereign
1973 Argosy 24
Edmonton , Alberta
OK! Solved the dilemma...The FUSE PANEL in 76' was a part of the Univolt...
The PO just eliminated it all together.
Old 07-21-2014, 03:26 PM   #8
1974 Argosy 20
Kooskia , Idaho
Fuses? we don't need no stinking fuses!
Amzing what PO's do.
Old 07-25-2014, 06:40 AM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I can't decide if this or the electrical tape propane repair is more dangerous... decisions, decisions. The propane offers the possibility of explosions, but this one offers a stronger element of randomness, being more likely to be a random issue that could affect you years down the road, or never!
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-25-2014, 08:00 AM   #10
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Stork,
Your original post is confusing, where you mention converter and Univolt, when you match up your reply #6, which relates to 120V.
'Argosy 7728' is correct in his post, as my 120V breaker box is between the beds while the converter/Univolt with 12V fuses is by the curb side wheel well ('76 Argosy, rear twin beds and centre bath).
I trust this helps,
Chris
newsgauger is offline   Reply With Quote
Old 07-26-2014, 07:19 AM   #11
1977 Argosy 28
Irrigon , Oregon
newsgauger, is your battery on the curb side as well? it's interesting how much variations there are
Rod
AIR# 60278
centre caps and lug nuts truckasaurus Wheels, Hubs & Bearings 0 06-19-2014 08:37 PM
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
Music Centre wiring? Dastardly 1970-79 Tradewind 2 08-22-2011 04:43 AM
Feedback from Jackson Centre? Wingeezer Airstream "In the News" 2 08-03-2009 07:03 PM
