Old 07-31-2008, 11:43 AM   #1
1975 Argosy 24
1975 24' Argosy 24
Decatur , Georgia
75 Argosy 24 Inside Lights
We have just purchased and are in the process of restoring a 1975 Argosy 24. We cannot get the inside lights to work. Do they run off a battery?
Also cannot get the pump to work. Any help would be appreciated. Thanks.
rusty47 is offline   Reply With Quote
Old 07-31-2008, 11:56 AM   #2
mandolindave's Avatar
Do you have a volt meter
Yes the inside lights were originally powered by the battery. Many of the components of that vintage trailer are most likely about ready to break down. I would start with a new battery ( after all safety issues were addressed of course, ie brakes, tires, bearings) Although I would bet that you don't have the original battery. The old battery chargers are notorius for boiling batts if you leave them on too long. There is a section on electrical sytems under forums. If you get lost, just ask for help.
mandolindave is offline   Reply With Quote
Old 07-31-2008, 01:20 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Rusty47!
Welcome to the Forums and the world of Vintage Argosy ownership!
Basically, all systems operate on 12-volt DC in your coach, including: furnace blower motor, range hood vent motor, interior lights, bathroom vent fan motor, interior vent fan motors, and water pump. If you do not have a fully charged battery or a working power converter that is plugged into 120-volt AC, none of the above would be operable.
Most of the time, the power converter (Univolt) is located in the cabinet under the front soafa very near the battery compartment. There is a 12-volt fuse panel mounted on the power converter (assuming original Univolt or similar replacement), and this power converter is then plugged into a standard 120-volt AC outlet. The 120-volt AC distribution panel is often found in one of the closets/cabinets in the rear street-side corner -- sometimes, you will find that a previous owner may have switched off the circuit to the power converter.
If your coach has the original PAR (Peters and Russell) water pump, and it isn't currently pumping water but does run; it is rebuildable and will likely outlast several of the new replacement pumps. You may have to go to a Marine shop to find a rebuilding kit as Airstream was one of the few RV companies to utilize the PAR product -- it is most often found in the boating industry. My '78 Minuet still has its original PAR pump, and it is currently awaiting a rebuild kit to return it to full functionality.
Good luck with your coach!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
overlander64 is online now   Reply With Quote
1972 Argosy tail lights - free to good home bobfowler All Argosy Trailers 8 05-06-2008 06:24 PM
Will Adding a Front Rock Guard Set Make Our Argosy too Dark inside? AndyPenny All Argosy Trailers 5 03-27-2008 07:00 AM
Clearance Lights For 76 Argosy Gkiesel Lights - Interior & Exterior 3 04-23-2007 03:55 PM
1975 Argosy Need wiring diagram to repair directional lights, etc. Rt66Argosy Member Introductions 2 09-27-2006 09:51 AM
paint inside argosy? fixbymark All Argosy Trailers 6 06-22-2006 08:18 PM
