Old 02-14-2015, 03:47 PM   #1
1976 31' Sovereign
Chester , Vermont
'74 Sovereign Univolt
Plugged into shore power. The univolt hums. No battery connected (small compartment, btw. Is that normal ?). When all DC lights are on, power cuts, so we only keep a couple lit at a time. I want to replace univolt. Suggestions? Will I be able to turn all overheads on at the same time?
Thomasmg is offline   Reply With Quote
Old 02-14-2015, 03:51 PM   #2
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
You know why it hums? It forgot the words! Badabum tishhh! Thank you, I'll be here all week. Try the veal.
Sorry, I've got nothing on the univolt. Somebody on here will be able to help. Good luck with it!
-Red, almost regretting the joke now..
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-14-2015, 03:52 PM   #3
1994 34' Excella
Warren , Manitoba
I replaced the Univolt in our 1976 with a Progressive Dynamics with charge wizzard, 30 amp. Used the panel from the Univolt, and put in the same place as original. Worked great, no hummmm, and no more battery problem. One of the best things I did for the old girl!!! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-14-2015, 03:53 PM   #4
Panama Red's Avatar
Obrien , Florida
One thing though, a new charger/power supply had just been put in my '74 when I bought it, and I can turn on EVERYTHING 12 volt in the trailer with no battery connected, so, yes, with a new one, all the lights are no problem.
-Red, trying to be helpful after all..
Old 02-15-2015, 10:43 PM   #5
New Borockton , Alabama
Images: 21
They are not difficult to replace. From that era, you may or may not also need a DC fuse board to go with it. If your DC fuse board is on the wall, you don't need the FB9 fuse board. If its integrated into the end of the Univolt, you do. This is usually a do-it-yourself project and not expensive or difficult.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 02-15-2015, 11:07 PM   #6
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I replaced the Univolt in our '69 Tradwind with a PD 60 amp with charge wizard
My Univolt did not have a fuse board.
It had a separate fuse block in the rear compartment with glass type circuit breakers and fuses.
I relocated it to the curb side compartment after rebuilding and updated it with MaxiFuses and circuit breakers and even the light.
ID:	232512   Click image for larger version
ID:	232514   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-16-2015, 06:53 AM   #7
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
If your univolt still works its a small miracle. They are noisy because of the way the diodes and capacitors work. If you are handy, the Univolt can be repaired. The dodes and capacitors are available at Galco. But.... a new box is cheaper than replacement parts.
Everyone here has their preferences. They all will work. A replacement can be found at Amazon. Find what you like based on your needs and read the reviews. Good Luck
Clayton
NavyCorpsman is offline   Reply With Quote
sovereign
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
How do I get at Univolt in 1995 Sovereign? johnobuttons Batteries, Univolts, Converters & Inverters 0 05-14-2009 06:23 PM
Sovereign Intelli-power Univolt swap ALANSD 1974 - 1979 Sovereign 19 01-12-2008 03:41 PM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
Univolt Replacement rjones1138 Electrical - Systems, Generators, Batteries & Solar 19 10-21-2002 03:31 PM
