Old 08-26-2009, 08:59 AM   #1
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
'73 Overlander Univolt removal
Ok, I have looked on the forums and don't see anything specific to this year/model Can someone please tell me how to get the univolt out of that "little" hole?
thanks, bruce
bwoodtx is offline   Reply With Quote
Old 08-26-2009, 11:35 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
My 73 had the univolt stuck under the end of the tub,I think it took about a 12 pack,and some choice words. Dave
easyride is offline   Reply With Quote
Old 08-26-2009, 02:09 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you have twin beds (note sure how doubles are set up).... try unhooking it and pulling it forward - remove the mattress and flip the bed support half over - lift it up out.....
Old 08-30-2009, 05:51 AM   #4
Clyde-2's Avatar
1972 27' Overlander
Bonita , Texas
My 72 has it under the tub as well. Don't think I will tell the wife that when she takes a bath she is just inches from high voltage.
Link to my restoration blog:
http://www.airforums.com/forums/blog...7-clyde-2.html
Clyde-2 is offline   Reply With Quote
Old 08-31-2009, 08:46 AM   #5
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
My 71 had it under the tub too.
I moved it out and under the twin. Is it okay to be mounted under the twin? Does it need air circulation? I can't imagine that it has less air circulation than in that creepy hole. Thanks for all the knowledge....TRULY APPRECIATED!!
WILDRTEXAS is offline   Reply With Quote
Old 08-31-2009, 10:14 AM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Bruce, if you still need help with this, I can shoot you some pictures and an explanation tonight (I'm assuming you have a rear bath?).
www.nesa.org
Air No. 6427
Old 09-01-2009, 06:55 AM   #7
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
thanks jim. yes it is a rear bath. some pics and an explanation would be truly helpful.
Old 09-01-2009, 07:26 AM   #8
Got gandkids?
WIll do tonight.
www.nesa.org
Air No. 6427
Old 09-01-2009, 09:43 AM   #9
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
I know Jim will chime in on this later but I have a couple of photos here at work that may be of assistance. I took these when I had a leak right above my Univolt.
I drilled out all the rivets on the "shelf" above the tub and removed that panel.
THis shows my temporary fix to my leak, but just past the fittings you can see the univolt
I do not know how the Univolt is anchored. I would assume that the best way to get to whatever anchors it is this route. I'm thinking the removal would have to go forward towards the twin bed and out the storage door or, if the bed is removed, out that way.
Are you getting a new inverter/charger? What kind? Will you be putting it where the Univolt came from?
biggoofball is offline   Reply With Quote
Old 09-01-2009, 10:01 AM   #10
Got gandkids?
Good stuff, Skip. Kudos to you!
The Univolt sits on a wooden "shelf" that's built over the top of the battery box. That shelf is screwed into the floor with 3/4" self tapping screws. The Univolt is screwed to that shelf. I actually still have the Univolt attached to that shelf, and the shelf removed from under that bath. I'll take a snap shot of it tonight and post it here.
www.nesa.org
Air No. 6427
Old 09-01-2009, 04:51 PM   #11
Got gandkids?
Here you go. Let me know if you need more detail.
ID:	86478   Click image for larger version
www.nesa.org
Air No. 6427
Old 09-01-2009, 05:54 PM   #12
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
thanks to everyone for all of the info and wonderful pictures!!! doesn,t seem quite so intimidating now. thanks again!!
bruce
Old 09-02-2009, 08:19 AM   #13
Ottawa , ON
The service manual for the 1974 models says:
a. Disconnect power cord for 120 volts.
b. Switch circuit breakers to "OFF" position.
c. Remove panel or open door to Univolt area.
d. Remove two screws at front of Univolt which secure the Univolt's plywood base to the Univolt stand. Do not remove at shock mount area.
e. Disconnect harness wires from face plate of Univolt.
f. Disconnect 120 volt Romex wire in area below face plate.
g. Slide Univolt and plywood base out.
h. Prior to reinstalling Univolt, inspect shock mounts for tightness. The steel legs of the Univolt should not come in contact with plywood base. The shock mounts reduce the Univolt's noise from "telegraphing" through the trailer.
i. When reinstalling Univolt/plywood base addembly, be sure the base is positioned under the rear mounting bracket.
...hope this helps. Some of the phrases aren't clear to me, but I suspect they will become clear when I actually take the Univolt out.
Old 09-02-2009, 08:34 AM   #14
Ottawa , ON
Jim,
Thanks for the photos. After my previous post, I looked closer aat your photos, and image #DSCN8496.jpg appears to show that there is a piece of plywood that the Univolt is fastened to that is then fastened to the larger wooden structure.
If I'm seeing things correctly, then I think that the manual indicates that removing the entire wooden structure isn't necessary, but rather just taking out the smaller piece the Univolt sits on will acheive removal.
Does that make any sense to you? It also talks about making sure that the rear securing strap is engaged. Did you see such a thing when you took it out?
One last question: I'm thinking that you unscrewed and removed the front door of the blue metal Univolt case. is that right?
Thanks again,
Aage
73 Overlander bathroom cabinet mirror removal / Help? Lothlorian Cabinets, Counter Tops & Furnishings 2 07-13-2009 07:09 AM
73 overlander refrigerator removal plan? Lothlorian Refrigerators 3 06-20-2008 06:29 PM
1966 Overlander ... Bathroom removal gitnmybelly Sinks, Showers & Toilets 17 02-12-2006 10:49 PM
removal of furnace in 61 overlander heavyduty Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2005 03:50 AM
Oxidation removal on 63 Overlander jwi1939 Cleaning, Stripping & Polishing 0 03-04-2003 07:15 PM
