Old 09-02-2009, 10:23 AM   #15
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I removed the entire structure because I'm going to reinstall it away from the shower, probably underneath the bed. Once the wires are disconnected, I think all you need to do is remove the four sheet metal screws that hold the Univolt to the plywood base. Then you should be able to simply lift it straight up and out of the compartment. And yes, the door that covers the fuse panel was removed by a PO for some reason.
www.nesa.org
Air No. 6427
73 Overlander bathroom cabinet mirror removal / Help? Lothlorian Cabinets, Counter Tops & Furnishings 2 07-13-2009 07:09 AM
73 overlander refrigerator removal plan? Lothlorian Refrigerators 3 06-20-2008 06:29 PM
1966 Overlander ... Bathroom removal gitnmybelly Sinks, Showers & Toilets 17 02-12-2006 10:49 PM
removal of furnace in 61 overlander heavyduty Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2005 03:50 AM
Oxidation removal on 63 Overlander jwi1939 Cleaning, Stripping & Polishing 0 03-04-2003 07:15 PM
