Old 09-28-2018, 10:20 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
72 Safari Univolt went out
So just bought this trailer and brought back to Texas. When I plugged the trailer in the Univolt and 12 V system was working but making a loud hum. Decided to leave the trailer plugged in last night so when I came home after work today the hum was gone along with all 12Volt lighting.
the 120 Volt system was fine. So any thoughts on this? Fuses? The Univolt is located in the back bath closet and like anything else in this old trailer is subject to replacement. Thanks for some tips.
RichHog is online now   Reply With Quote
Old 09-29-2018, 06:58 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
The old univolts make fine boat anchors.
Seriously, it could be a fuse, it could have cooked your battery or it could be dead. In my opinion, don't mess with it. Call Randy at Bestconverters.com and order a new converter. Tell him what your trailer is and he will recommend the one that fits your needs. The technology of the new charger/converers will keep from overcharging and maintain the battery without damage. They are also much quieter than the old univolts.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-29-2018, 09:08 AM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
45+ years is a good run. Almost anything made in the last 15 years would be a vast improvement, though a decent three stage converter would probably be the most cost-effective replacement. And it will be about 30 pounds lighter...
Old 09-29-2018, 09:46 AM   #4
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
converter
I would also recommend Randy at bestconverters.com .
Tell him what you have and he will set you up.
1972 Ambassador Itn'l 29'.Custom Interior FOR SALE.
1978 Avion 34W
Airline is offline   Reply With Quote
Old 09-29-2018, 10:29 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You really wanted to change it whether the old one is working or not.
Old 09-29-2018, 10:38 AM   #6
belen , New Mexico
The hum alone will drive you nuts.
alantbird is offline   Reply With Quote
Old 09-29-2018, 10:56 AM   #7
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Univolt
yes and after I get the black water tank out I'll lie on my back and see if I can get to the thing, Along bottom floor in the bathroom near the corner.
Now I know why the PO didn't replace it.
Old 09-29-2018, 11:19 AM   #8
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The output capacitors in the beast have almost certainly gone dead. The resonator capacitor is likely gone as well. Yes, you could go crazy rebuilding the beast. Why would you? The modern units are a lot better at what they do.
Also on the list to dig into:
1) Battery(s) likely need replacing - do that after the converter is swapped out but before you go anywhere ( no working battery = no breakaway function ... yikes ...)
2) Brakes should be checked on any "new to you" trailer or MH
3) Hubs need to be checked / lubed.
4) Tires over about 6 or 7 years old should be replaced
5) Water system should be flushed / cleaned / bleached.
6) AC should be checked. The motor start capacitor is in the same kind of "past use by date" category as the converter electronics.
I'd start saving up to convert the lights to LED's but that's not in the same category as any of the stuff above.
Old 09-29-2018, 12:42 PM   #9
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
This is actually a good thing. The old univolts are, not worth fixing. You will enjoy having a charger that you don’t need to monitor. Less to worry about more relaxation. My 71 GT has an automotive portable battery charger hard wired in. That was first thing to go. Enjoy your new one!
bibbs is offline   Reply With Quote
Old 09-29-2018, 12:55 PM   #10
1970 25' Tradewind
Chicago
I gutted my univolt to keep existing fuses and connected new converter to hot and neutral on fuse board. Used heavy gauge wire so I could move new converter to a more accessible location.
Madmarke007 is offline   Reply With Quote
Old 09-29-2018, 03:56 PM   #11
Well Preserved
1993 21' Sovereign
And now, for the only Univolt joke I know:
Q: Why do Univolts hum?
A: Because they don't know the words.
Thank you, I'll be here all weekend.
Old 09-29-2018, 04:04 PM   #12
Half a Rivet Short
Hi
Ok, so since you asked ....
Univolt's hum because of the type of voltage regulating transformer they use. The core's magnetic field is a bit overwhelming and there's really no way to keep it from vibrating everything around it.
Old 09-29-2018, 08:31 PM   #13
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Hi
Thanks Bob and now I know...
I was going to bring in my Vintage Turntable with my vintage Technics amp that Iím sure will love that 70 s to Univolt power supply while
Old 09-29-2018, 08:32 PM   #14
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Listening to Jefferson Airplane.
Battery system just went out...help! kirkland1833 Batteries, Univolts, Converters & Inverters 7 03-03-2013 10:03 AM
2010 Flying Cloud - A/C Just Went Out forthefew Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-02-2011 09:39 AM
12 volt went out dorfgog Batteries, Univolts, Converters & Inverters 9 06-18-2010 09:32 PM
Help- Control Panel went out all at once milesmason Electrical - Systems, Generators, Batteries & Solar 10 06-29-2006 09:56 PM
