Old 04-01-2010, 05:47 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
$700 in parts! Thats just the start
Well I just picked up the box of parts I ordered. I am replacing the manual single switch with three, yup three magnetic latching relays. My two current batteries are at the end of their lives. I am adding a third battery at this this time. I have to remove the couch to re-arrange the mess under there to make room for the third battery box.
I am going to have to vent it through the floor and belly pan.
After all this I will be installing two additional solar panels, a new controller and display panel.
Michelle TAC MT-0
Sarah, Snowball
Old 04-01-2010, 05:57 PM   #2
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Maybe I am not thinking about it correctly, but I thought the reason a battery needed to be vented is to allow hydrogen produced by charging to to dissipate. Doesn't it need to be vented upward or at least level?
Regards,
Ken
Old 04-01-2010, 06:21 PM   #3
Keymar , Maryland
Regards,
Ken
Ken,
The box has top and bottom vents. The bottom vent is for air in. The top is air/hydrogen out. It is a sealed box for use with any type of battery. I want a vent outside the trailer in case of acid spillage.
Michelle TAC MT-0
Sarah, Snowball
Old 04-01-2010, 07:36 PM   #4
_
hi michelle
why not just connect the 3rd box to the other 2 boxes up front...
they both vent OUTSIDE so connecting the 3rd box between them would provide 2 way air flow.
are you planned to use flooded wet cells or AGMs?
cheers
2air'
Old 04-01-2010, 08:56 PM   #5
Keymar , Maryland
Originally Posted by 2airishuman View Post
hi michelle
cheers
2air'
I though of that but the only sealed box I could find locally has top and bottom venting. I want sealed in the cabin. Getting a Hose from one box to the center one to the other will be on the way of a lot of wiring. I could cut off and seal the bottom fitting hole. The wiring will be redone as well.
Most likely AGM's. They won't be Lifelines though. They are nearly $900 for three.
Trojan Sealed Group 27s. I know I don't really need venting but I want it. You never know when a battery is going to let go of something.
Michelle TAC MT-0
Sarah, Snowball
Old 04-01-2010, 09:20 PM   #6
_
yeah the venting is tricky with top/bottom holes.
the current/oem boxes are elevated, sitting on a section of 2x4 slightly above the floor.
the new box could be done this way too IF access to the bottom hole is really wanted.
with agms one vent tube seems adequate, connecting to either oem box, leading outside.
going DOWN through the subfloor and belly wrap seems extreme.
_________
the lifelines can be purchased with the 'concorde' label (exact same battery) for less money...
the difference is the warrany but the batteries are identical...
_________
IF u have not had the sofa OUT ever it'a a real treat.
-empty then pull the slide out drawer 1st.
-4-6 bolts into the subfloor and the sofa is FREE.
-PULL forward (past the charger/converter) then rotate the curb side slightly (i use furniture sliders UNDER the metal rails...
it' will fit OUT the door but that's 2 person job.
not sure if there is room in the 30/31 to leave it in front of the galley/open space...
take more pics!
and i hope that lpg gas hose/tank connector (in the photo) has nothing to do with the battery install...
cheers
2air'
Old 04-02-2010, 05:13 PM   #7
Keymar , Maryland
2air,
I will be removing the couch but not from the trailer. I will see if the battery box will sit up high enough to vent but low enough to allow someone to sit on the couch.
I looked at the concorde's. I could not find a G-27 equivlent. I did find one in their Solar line up. Those are probably even more.
The LP gas line is to fill the sealed batteries when the electrolyte gets low.
Actually, I am installing it on one side so I can drop in a 20 or 30 lb tank on one side.
Michelle TAC MT-0
Sarah, Snowball
Old 04-02-2010, 05:53 PM   #8
Lily&Me's Avatar
Normal , Illinois
And good for you for having the ability to do all this yourself.
Maggie
Lily&Me is online now   Reply With Quote
Old 04-02-2010, 07:26 PM   #9
_
the 'sun extender gp 27s agms are ~780$ for 3...
based on a quick search.
less than L/L but still a big gulp.
cheers
2air'
Old 04-04-2010, 09:10 PM   #10
Keymar , Maryland
cheers
2air'
I looked online for the lifelines, the Sun-Extender and the Trojan AGMs. All about $250 each. That will come in May. April's expense will be a new power panel. It is a good thing the tires are in good shape for my trip east this summer.
Michelle TAC MT-0
Sarah, Snowball
Old 04-04-2010, 09:23 PM   #11
Keymar , Maryland
take more pics!
cheers
2air'
Well this afternoon I pulled the sofa, stoop it on end outof the way and gutted the DC power system. Distribution remains intact for now.
The new solar controller is installed as well. It is rated for 45A. the old one 20. Adding the new panels will being the max possible current up to 18A.
I tried to upload pictures this evening just is not working.
Michelle TAC MT-0
Sarah, Snowball
Old 04-04-2010, 10:20 PM   #12
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Michelle, I've missed your discription of your solar set up. What solar panels did you use, or what would you suggest for this year?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 04-05-2010, 08:49 AM   #13
Keymar , Maryland
I have Factory BP Solar 50+W. I am adding Sharp 80W in parallel with the factory panels since they have similar characteristics. The factory controller would have burned up under a full load. It is a tiny thing.
Michelle TAC MT-0
Sarah, Snowball
Old 04-05-2010, 04:34 PM   #14
Keymar , Maryland
Pictures
Finally the pictures
First the couch by the door with my supervisor looking on.
second the current electrical mess.
Third the original solar controller.
Forth the new solar controller
Fifth the DC system gutted and a preview of the new battery box.
ID:	99530   Click image for larger version
ID:	99532   Click image for larger version
Michelle TAC MT-0
Sarah, Snowball
1969 Magic Chef Oven Model TL 700-2? CJ of Okla 1965-1969 Sovereign 1 04-09-2017 11:31 AM
Proper tire size. 700/15? 6ply Zstream Tires 7 03-09-2011 11:33 AM
Vintage 'Skinny' 700-16 Tires Benjo Tires 5 12-01-2009 01:15 PM
700-15 vs. ST225/75/15 chuman70 Tires 7 07-20-2007 04:52 AM
