Old 06-14-2017, 02:30 PM   #1
Hans627's Avatar
2009 25' FB International
Hanover , Pennsylvania
7-Way Trailer Receptacle
I've had my AS for two years now and I have never been happy with the 7-way receptacle. I am concerned about the lack of strain relief and that water may get into the receptacle and corrode or even cause a short. The pictures show the issue.
The current receptacle is a replacement and the umbilical cord is already marginally long enough.
Is there a way to provide strain relief and seal the water entry point at the same time?
As always, any input is appreciated!
ID:	287562   Click image for larger version
Old 06-14-2017, 02:54 PM   #2
WaLee's Avatar
Nevada City , California
You could get an extension from pro pride just bungee up the excess if need be i know they sell one due to the increased connection length the hitch creates
WaLee is offline   Reply With Quote
Old 06-14-2017, 02:59 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
On the plugs I have installed, when you tighten the halves of the housing together there are ridges that tightly grip the outer covering of the umbilical wire. Pretty much sealing it and providing strain relief. Looking at the pics, and I may be wrong, it looks like you may not have trimmed the 7 leads short enough. If they are shorter then the outer cover of the umbilical will be gripped when you put screw it together. Takes a little trial and error to get the lengths just right.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-14-2017, 03:36 PM   #4
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
You can pack the plug and cord entry into the plug with dielectric grease that will keep water out and prevent corrosion.
John Woodrow is offline   Reply With Quote
Old 06-16-2017, 02:32 PM   #5
Hans627's Avatar
Thanks for all the suggestions. I took the receptacle apart and understand why the the wires were so long. The back of the receptacle (under the black plastic cover) required that the wires be out of the sheath an extra length to be able to fit the two half together (I should have taken a picture as it would make it easily understandable).
So I went to Camping World and got a new receptacle and installed it this afternoon. Looks much better and it has a seal that will keep the water out.
Again, thanks!
Old 06-16-2017, 03:15 PM   #6
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
That's a Hopkins isn't it?
I tried that new ergonomic design and wired it up two times trying to get a decent strain relief. And I consider myself pretty good with automotive wiring.
I gave up it's a poor design that offers no real merit. It's sitting in my shop as a reminder of a mistaken purchase.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-16-2017, 03:19 PM   #7
Hans627's Avatar
Gary
Yes it is a Hopkins and I have to agree that it is a poor design. I'm not sure they even make it anymore. When I did a search for a new receptacle it did not show up anywhere.
The straight receptacle is much better and has good strain relief and water seal!
No Power to Trailer When Hooked to 30A Receptacle hwm Electrical - Systems, Generators, Batteries & Solar 2 05-21-2017 07:38 PM
electrical issues > Tow Vehicle pin out not matching Trailer receptacle taddilack Electrical - Systems, Generators, Batteries & Solar 3 08-04-2014 12:21 PM
Antenna/TV receptacle Al1 All Argosy Trailers 11 07-06-2004 01:20 PM
Electrical receptacle in storage compartment Kistler Our Community 4 06-27-2003 08:18 PM
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 08:19 AM
