Old 05-27-2008, 08:31 PM   #1
1969 23' Safari
South Lyon , Michigan
69 Safari Univolt system
Hi just purchased a 1969 Safari, this is my first Airstream.
I went to hook up a 12v radio in it, I checked power at the wires from were the old radio used to be and I am getting 16.5 to 23 volts DC.
Any ideas?
Protosport is offline   Reply With Quote
Old 05-27-2008, 10:54 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Are you running this plugged in only with no battery in the system or just battery? I would guess you're plugged in, which case if you have a battery installed the univolt is probably boiling your battery. The univolt is what converts your power to 12v from 110. On a 69 if yours is like ours its a blue box wired in the compartment (passanger side) under the wheel weel/tub area. Worth checking to see if you get more than the usual voltage at those terminals. If so I would guess the unit is fried and would disconnect it before you damage any electrical items. We installed a intelipower with charge wizard at the recommendation of users on here. It is absolutely quiet (no hum) and helps keep the battery in check.
goransons is offline   Reply With Quote
Old 05-28-2008, 03:02 PM   #3
1969 23' Safari
Thanks for the infomation. I ordered a converter today.
'69 Safari 110v system not working Skiffy Batteries, Univolts, Converters & Inverters 1 07-17-2007 07:31 PM
Univolt System for charging rozwd Electrical - Systems, Generators, Batteries & Solar 9 10-02-2006 07:50 PM
Univolt Surprise 71 Safari silvercomet Electrical - Systems, Generators, Batteries & Solar 5 06-08-2006 08:03 PM
1977 23' Safari Plumbing System RamblinRose Plumbing - Systems & Fixtures 5 07-26-2004 12:32 PM
How to check charging system (69 Safari) Bob Boucneau Electrical - Systems, Generators, Batteries & Solar 2 07-14-2003 10:48 PM
