Old 04-05-2010, 08:35 AM   #1
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
68 Globetrotter wiring
I'm trying to determine a couple of things about a friends 68 GT:
is it normal for none of the 12v system to work unless a battery is installed? i.e. does the battery 'complete' the loop or system? or should the univolt provide 12v power if hooked to shore power - regardless of the battery?
also, is the a website that has the original wiring schematic available?
I have other questions but I'll wait on the above answers
Doug
59er is offline   Reply With Quote
Old 04-05-2010, 09:00 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
You should use and need a battery.
Here is a diagram for a 67 GT. It will help if no one comes up with a 68.
Name:	Airstream manual 49.jpg
ID:	99518   Click image for larger version
Name:	Airstream manual 51.jpg
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-05-2010, 12:16 PM   #3
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
that gets me pretty close. the battery on this unit is located @ the back rather than the street side.
And, there are two sets of DC wires with "ring" attachments for wingnut posts... not sure if those are both factory wires or if one set is an add-on?
Doug
Old 04-07-2010, 07:44 AM   #4
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
ok...here's what we have currently.
the two huge (double) wires in the center of the pic appear to be the original 12v wiring for the battery connections and the two add-ons to the right look like maybe someone added those onto the 'romex' type wire. I'm guessing maybe the univolt stopped putting out DC so they 'straight-wired' the 12v system to the battery?
any guesses?
Doug
Old 04-10-2010, 12:00 PM   #5
Birmingham , Alabama
what do the M and S represent on the low voltage schematic? Thanks
scssmith is offline   Reply With Quote
Old 02-20-2014, 11:57 AM   #6
1967 20' Globetrotter
Picayune , Mississippi
need wiring diagram for 67 GT
I Have a 67 gt that i'm restoring where can i get the book that wiring digram came out of
Scott-N-Deb is offline   Reply With Quote
New to me '63.......Globetrotter Overlander & Sea 1960 - 1964 Globetrotter 38 05-29-2013 11:28 PM
'62 globetrotter wunderful62 1960 - 1964 Globetrotter 19 10-29-2006 03:01 PM
64 globetrotter cpinkston Sinks, Showers & Toilets 2 06-14-2006 02:07 PM
Just got our first AS...'65 Globetrotter! grnthumbguy 1965 - 1969 Globetrotter 4 09-08-2005 11:22 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
