Old 08-02-2012, 01:38 AM   #1
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
'67 Caravel electrics - advice please
Can anyone give me some info on this unit. I don't believe it has any 110v input but the switching is prompting me to delve further. It recently stopped working and I plan to replace it with an Inteli-Power 9270.
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 08-02-2012, 06:03 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Originally Posted by Moonstruck View Post
Attachment 164495
It has to have 110 input to work on "City Power" It may be disconnected at the moment.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 08-02-2012, 06:07 AM   #3
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Which wire is which?
These are the other pics that I have. Is there any obvious way of detecting the 120 input as I can use it to power the new converter?
There's no obvious transformer down to 12v.
Silvertwinkie
Hampshire, UK
Old 08-02-2012, 07:05 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
It looks like that panel is the 12V side of the converter. From the breaker box (where the shore power cord connects) you should be able to find a wire running to the converter. The newer converters have a standard plug on them. I installed a new 120V outlet box under the sink in the bath next to the breaker box and ran the cable that used to go directly into the old Univolt into the outlet box. Makes it easy to unplug the converter if I need to take if off line and also gives me another 120V outlet in the bathroom. The panel you pictured is the 12V box and you can either stay with it or install a new one. I kept my old 12V box since it was in the "Central Control" in the galley. I cleaned all the connections ( I have aluminum wire) and all works fine.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-02-2012, 07:25 AM   #5
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
I see!!
So, I have to play, "hunt the converter". The shore power enters a junction box at the other end of the "electrics" storage under the sofa, then down the chassis to a breaker box in the bathroom wardrobe. I'll start there.
Silvertwinkie
Hampshire, UK
Old 08-02-2012, 08:46 AM   #6
1974 Argosy 20
Kooskia , Idaho
I think a PD 9270 is a bit of overkill. Most seem to be happy with a 9245 or at most a 9260. The last two numbers are the amp capacity. Initial charging with a very low battery may be a bit higher with a higher capacity unit, but it quickly tapers off to something the battery can deal with anyway.
Just something to think on.
Old 08-02-2012, 12:36 PM   #7
Barkingdogg's Avatar
Newcastle , Oklahoma
I had a 67 Caravel. My converter was under the sofa bed, between the wheel well and the bath wall.
Barkingdogg is offline   Reply With Quote
Old 08-03-2012, 01:03 AM   #8
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Woof!!
I know you're right! I know the bit you mean and your description of it's location is spot-on!
I agree that the 70 Amp is, as we British so quaintly put it, "Gilding the Lilly". However, I don't have a choice in the matter. My friend recently imported a Tradewind and I recommended he get a new converter. When it arrived we discovered it had a fairly new hybrid(120/12v) unit.
I took the chance to buy it at cost as the only supplier of them over here, a man who shall remain nameless lest I am compelled to slander him, charges $ 550 for a 30 Amp!
Marc
Silvertwinkie
Hampshire, UK
caravel
