Old 02-24-2008, 01:59 PM   #1
max7's Avatar
1965 20' Globetrotter
Apple Valley, CA , California
66' AS Safari ?
Just bought a 66' AS Safari. Removing the rear access panel I found some cut wires coming out of the interrior wall of the trailer. Any idea what they went to? Also the one disconnected in the juction box? Thanks!
max7 is offline   Reply With Quote
Old 02-24-2008, 02:55 PM   #2
Midamrail's Avatar
1975 Argosy 26
Villa Ridge , Missouri
I'm not sure about the wire in the box, but the wires in the corner likely went to your Univolt converter. That's where the Univolt in our '64 Tradewind was located.
Both Alex, my Argosy, and I are kids from Versailles, Ohio!
Midamrail is offline   Reply With Quote
Old 02-24-2008, 03:35 PM   #3
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Hi Max7:
Welcome to the Forums! I second Ms. typing Molly's observation. That space on the left to the rear of the water heater is where your Univolt was, but good riddance to its ancient technology. Buy an Intellipower or WICO Converter with 3 stage battery charger to replace the thankfully gone Unifry. Then you can build a battery mount roughly under the plastic battery cover, buy a nice battery to go in it, and get youself wired up. I don't know why all the buss fuses are missing near the detached large wire, but I suggest you find out before replacing them and running power through them. Have fun with your neat old Safari.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 02-25-2008, 07:39 AM   #4
centennialman's Avatar
2016 23' International
Centennial , Colorado
Max,
The wires on the left side went to the univolt. My '66 Safari now has a regular electrical receptacle there and my converter plugs into it.
I will get some pictures of how the 12 volt is wired and post them for you.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 02-25-2008, 09:52 AM   #5
Here we go Max....hopefully the pic comes out ok.....let me know if you have any other questions.
Old 02-27-2008, 07:54 PM   #6
max7's Avatar
Thanks you guys... just got back from Vegas.
22 safari sport vs. 20 safari jeffrho Member Introductions 10 01-04-2008 07:52 PM
Window Clips for 66', 67', 68' Are....In BIGED52 Windows & Screens 10 09-05-2006 02:34 PM
Replacing toilet in 66' Tradewind Gingergirl Sinks, Showers & Toilets 49 08-29-2006 06:51 PM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
a 65 Safari in need NoDregs Member Introductions 10 12-07-2005 04:27 PM
