Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 03-30-2007, 09:17 AM   #1
59er
59er's Avatar
Profile:  1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 8
64 overlander - what the heck is this wire for?
I've been able to account for almost every wire in the back of my 64 overlander except these marked in the pictures? if you have any idea as to where or what they went to, please let me know.
(both pictures are from the rear of the trailer, street side, below the breaker box.)
ID:	34856  Click image for larger version
Doug
59er is offline   Reply With Quote
Old 03-30-2007, 09:24 AM   #2
59er
59er's Avatar
1964 26' Overlander
Images: 8
Sorry, the wording in the pictures is not large enough. here's what the one on the right says.
the loose orange wire goes to the on-board battery. no problem there. the other orange wire and the large white wire don't seem to go anywhere? i.e. they don't surface anywhere else in the trailer and don't seem to have any effect or disable anything when unhooked? My thought was, perhaps they pre-wire all of the trailers (per model) the same and only certain wires were used based on which options this particular trailer had? for example, maybe this trailer came with a two way fridge, but was prewired for three? just a thought.
Doug
Old 03-30-2007, 10:14 AM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
In the first photo, the new wiring suggests the cut wire was replaced, and just not removed from the interior skin. I know the older coaches didn't come with 3 way fridges, it is possible (probable) the wires go to equipment that is no longer in the coach, like an air pump or fan.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 03-30-2007, 12:31 PM   #4
59er
59er's Avatar
1964 26' Overlander
Images: 8
always possible. and yes, it is to be 'dead' on 12v or 110.
Doug
Old 03-30-2007, 12:34 PM   #5
Jacob D.
Jacob D.'s Avatar
Profile:  1964 26' Overlander
San Leandro , California
If I remember correctly, the orange & white wires in the back of mine went to two different circuits: one went to a couple of 12V outlets and also to the inside of the front endcap, where the stereo was; and the other went to the furnace.
Other circuits were: one for all the lights, one for the fans (ceiling and cooker), and one that was the return cable from the water pump switch by the door. If I recall correctly, those were all 12/2 sheathed cable, though.
The other possibility is that it's the cable that goes to the trailer-connector for charging the trailer from the tow vehicle, although I think that was blue/white in mine.
Jacob D. is offline   Reply With Quote
Old 03-30-2007, 01:32 PM   #6
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Doug, I have a couple of "wires to nowhere" in my '73. It looks like Airstream wired every Overlander with the same bundle, but only used the wires needed for the options purchased. For example, I have unused blue wires down the center of the ceiling that are tied to the charge line from the TV. Also, there is a yellow/white pair at the foot of the roadside bunk that I think was to be used to power a 12v television/stand that was not purchased.
Guess I'm getting old. Don't recognize any of the famous people in the "Got Milk?" ads any more.
www.nesa.org
Air No. 6427
Old 03-30-2007, 01:49 PM   #7
59er
59er's Avatar
1964 26' Overlander
Images: 8
Jim, that was my thinking...
Jacob, correct, I've got a large Blue wire from the TVehicles DC (if I remember right)...
and I can account for stink fan in bathroom, water pump switch, etc. but forgot about the furnace blower... I'll doulbe check it before leaving them undone.
any other thoughts on what that chopped 12/2 might have gone too? just curious more than anything I guess?
Doug
Old 03-30-2007, 02:38 PM   #8
Jacob D.
Jacob D.'s Avatar
If you're replacing the floor at the back there, you'll need to take off that wall panel anyway to screw the C channel to the floor - you might get a better idea then. That was certainly the first point where I could definitively trace all the cables in mine.
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 07:52 AM
tree on 69 Overlander pebblepoint General Repair Forum 2 09-10-2002 06:01 AM
2-door Overlander InsideOut 1958 - 1963 Overlander 0 08-30-2002 08:14 AM
Charging AC on 71 overlander smily Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-25-2002 05:33 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
