Old 05-27-2010, 10:23 PM   #1
1968 22' Safari
Regina , Saskatchewan
6.5 volts instead of twelve
Hello all!
This is my first stab at the forums. I am a newbie.
My wife and I recently purchased a 1968 safari. A buddy and I were trying to get the furnace fan/blower to cut in but it was just dead. We started checking the power going to the furnace with a volt meter it was reading 6.5 volts. So we started checking other places on the electrical system. Mainly we would get 6.5 volts but once or twice it was higher like close to 10 volts.
The fuses visually seem ok (two glass fuses on wall beside 120 fuse box)
Should we be getting 12 volts as a proper reading, If so does this probably mean my converter is toast?
Any info would help!
photoguy is offline   Reply With Quote
Old 05-27-2010, 10:30 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
If the converter is original to the trailer it is probably wise to replace it even if it isn't toast.
There's more to troubleshooting a dodgy 12 volt system than will fit in a forum post, but in short you should be starting at the battery and converter and working your way out from there.
Old 05-28-2010, 04:37 AM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Some converters need a battery to work properly.
If the converter is original it is a Univolt a big very heavy gray box that hums very loud and boils batterys it is best replaced with a modern 3 stage converter.
Garry
Old 05-28-2010, 07:23 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
You never mentioned if there was a battery in the system.
If so pull the fuses, taking all loads off the system, and measure the voltage at the battery. If the voltage is below 12.5 volts troubleshoot the battery and converter before going any further.
Yes if it is the original inverter get a new converter, preferably one that has 3 stages of charging functions built in it.
Once you have the battery and converter in good working order you can then replace the fuses and check the system. Voltage at each fixture should be very close to battery voltage before the fixture is turned on. Anything less than battery voltage at the disconnected input to a fixture indicates a problem in the wiring of that fixture or the ground you are connected to. If you can use a wire connected to the battery ground terminal as the ground side of your volt meter, reducing the chance you have a bad ground at the fixture. This wire should be #12 to reduce voltage lose in the wire while testing.
2004 Excursion 4x4
Old 05-28-2010, 03:10 PM   #5
1968 22' Safari
photoguy here
Thanks for all the info!! I'm pretty sure it's the converter then, I will get one and start from there, hopefully that will fix my voltage issues.
Thanks again.
12 Volts for Fridge? 85Sovereign Refrigerators 23 12-07-2010 10:36 PM
New 6 volts draining too fast ! Phantom Batteries, Univolts, Converters & Inverters 4 09-19-2009 12:54 PM
12 volts shutoff then come back on??? dnrtheil Electrical - Systems, Generators, Batteries & Solar 9 05-01-2007 10:54 AM
A twelve or two sixes ? Torii Electrical - Systems, Generators, Batteries & Solar 21 02-25-2006 08:08 PM
need to chance to 240 volts remcolent Electrical - Systems, Generators, Batteries & Solar 1 12-16-2003 06:49 AM
