Old 07-21-2013, 02:13 PM   #1
LFC
Memphis , Tennessee
55 amp converter.. free to good home
55 amp MagnaTek convertor...works fine.
I put a jell battery and replaced it.
It came in a 2000 Safari.
Like I said works fine...just pay large flat rate box shipping.
LFC is offline   Reply With Quote
Old 07-28-2013, 07:56 PM   #2
LFC
Memphis , Tennessee
It's a MagnaTek model 7455.
Old 07-29-2013, 05:59 AM   #3
LFC
Memphis , Tennessee
Gone
Old 07-29-2013, 07:09 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
That may have been a mistake. The converter provided you with much more that a very limited 12v supply from the battery...no matter how good and high AMPs.
Old 07-31-2013, 03:44 PM   #5
LFC
Memphis , Tennessee
The new smart convertor I installed works fine and I don't have to worry about it frying my jell type battery....and hopefully my old one will give the fellow that got it several more years of service.
Old 08-05-2013, 01:58 PM   #6
Chillpoints's Avatar
1992 29' Excella
Asheville , North Carolina
Working on installing it now.
Well that is almost the truth. I am ready to cut the wires on the old one to put in the new one but there is this troubling small black wire that comes out of the old magnetek Seen in the first photo. The second photo shows it coming in at the bottom of the converter charger with the white wire and then connecting on the side were there are some fuses? but not directly to the negative terminal. Any thoughts on where this wire goes? I have been trying to look in the owners manual and I opened the fuse box behind the goucho and it does not appear to attache there.
And a public and special thank you to LFC for passing along a converter that I hope will give me give me the service everyone brags about.
ID:	192500   Click image for larger version
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Chillpoints is offline   Reply With Quote
Old 08-06-2013, 06:00 AM   #7
LFC
Memphis , Tennessee
Looks like it goes with the white/negative wire ?
Before or after I cut it I'd get the cover off and see where it goes.
Old 08-06-2013, 08:30 AM   #8
1992 29' Excella
Problem resolved
LFC
After looking on the website for Magnetek to see if I could identify the wire, (no help) and then calling the engineer at Magnetek, who could find any documentation on an extra wire coming out of a 900 series, I did what any smart Airstream owner would do. I read the forum for about an hour. With a little investigative work and some simple test with the handy tester I was able to deduce that it was the 12v power line to the indicator light on the information center above the stove. It seems that Magnetek may have been producing these especially for AS back in the day. I found a nice diagram of a work around where you have a small 12v charger that you plug into the 110 outlet with the new power supply to power the little red light as it should. I did not copy the link last night and now can not find the correct link, Here is another posting that describes the situation a little better but does not have the nifty drawing that I saw.
http://www.airforums.com/forums/f449...ing-65867.html
Thanks to all who keep the forum a place to come get the questions answered. Once again it shows that the collective experience and education can solve lots of mysteries. Glad this is a place where we all work together.
Thanks again to LFC, The Converter/Charger works great so far and is so much quieter.
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Old 09-08-2013, 04:19 PM   #9
2002 34' Classic S/O
1972 31' Sovereign
New Cumberland , West Virginia
Penny
Need 55 amp ASAP ours went out today will gladly pay all shipping and handling fees
penny4moore@yahoo.com
304-670-9240
pennypearson is offline   Reply With Quote
Old 09-08-2013, 04:33 PM   #10
1972 31' Sovereign
Is it gone? What is the jell battery and where do you purchase? Does it replace the converter?
Old 09-08-2013, 04:59 PM   #11
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
"jell battery" is a gel battery of some sort, either an actual gel-cell or perhaps an AGM. They have particular needs for charging profile and are quite expensive, so don't buy one unless you actually need one.
The battery is not a replacement for the converter/charger, it was his reason for buying a better converter/charger.
— David
Old 09-08-2013, 05:00 PM   #12
1992 29' Excella
It is happily powering my system. Sorry yours went out. I hope you can find someone as nice as i did to pass their old one along.
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Good Sam Roadside VS AAA ThreeFingers Dollars & Cents 21 01-30-2012 10:01 AM
Free to a good home Excella CM Electrical - Systems, Generators, Batteries & Solar 0 01-02-2012 02:18 PM
AAA vs. Good Sam? jambie Insurance & Claims 39 09-30-2011 10:36 PM
Simple Q: 30 amp RV cord to 15 amp wall unit.. Shmeter Electrical - Systems, Generators, Batteries & Solar 2 07-17-2011 08:55 AM
Argosy Curtains - Free to a good home! RBolton All Argosy Trailers 7 05-19-2011 08:15 PM
