Old 05-09-2014, 07:34 AM   #1
2014 23' Flying Cloud
2015 28' Flying Cloud
Kalamazoo , Michigan
50 to 30 amp cord
What is the consensus on carrying a 50 to 30 amp converter in my FC 23D? Seems like cheap insurance for the few times I have only 50 amp service. Thanks
mwilliamsmd is offline   Reply With Quote
Old 05-09-2014, 07:40 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You never need one, until you do. I bought mine when attending a rally at a civic center that seemed to be set up for the big-moho crowd, all 50A sites with no 30A outlets. I've carried it in the trailer since then. I haven't needed to USE it since then, but it doesn't take up much room and I'll be ready next time.
— David
Old 05-09-2014, 08:15 AM   #3
1987 25' Sovereign
Oregon , Ohio
I bought one at the international rally in 2011 and needed it three weeks later at a campground in Ohio that only had 20 & 50 amp plug ins. Last year I was at a county fair ground for a unit rally. The electric boxes had two 20 amp, one 30 amp, and one 50 amp outlets, and the one 30 amp was already being used. No problem, I just pulled out the once used 50 to 30 amp adapter. I have only used it twice in three years, but when I needed it I had it.
msmcv51 is offline   Reply With Quote
Old 05-10-2014, 12:49 PM   #4
Lyle & Margie
2008 28' International CCD
Lakeside , California
I was told by a fellow AS person, on our first outing (Space Shuttle launch Feb 2010, tnx again Laura). That I should, when ever 50 amp is available, always use this adapter and to get my 30 amp service. I don't remember his reasoning (cleaner, and/or more stable, or?), but I've done this ever since, and it seems to work fine. Can anyone validate this process for me?
Tnx Lyle & Margie
BAB BMRZ is offline   Reply With Quote
Old 05-10-2014, 02:36 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is no validation.
50 amp is just 2 legs of the circuit where as 30 amp is just one leg of the same circuit and 20 is just a 20 amp beaker on the one of the 30 amp legs.
Now if the installer had wired ever 30 amp plug on the same leg throughout the camp ground you would see more voltage while plugged into the 50 if the adapter happened to take power off the unused leg. Likelihood about equal to winning the lottery. Because it would be completely against the code and raise hell with the campground electric meter.
2004 Excursion 4x4
Old 05-10-2014, 10:25 PM   #6
Lyle & Margie
Tnx Howie, I guess I can stop doing this.
Old 05-10-2014, 10:38 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
I don't think that is right. Each leg of a 50 amp RV circuit should be 50A at 120V.
Now, if the campground has more load than service on that 50 amp leg you will still have a low voltage problem. Using one leg of the 50 amp service is not a panacea and the breaker is oversized for your 30 amp shore power cable.
— David
Old 05-10-2014, 11:56 PM   #8
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
? That makes no sense at all. Sounds like your are talking about 220 volts which has two hot wires versus 120 volts which has one hot wire.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 05-11-2014, 12:00 AM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have used my 50 amp dog bone twice, but wouldn't leave home without it. A lot of 30 amp receptacles are loose or broken in that case the lesser used 50 amp receptacles would be a better choice.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-11-2014, 05:17 AM   #10
Gainesville , Florida
Robert, good point. I have found loose 30 amp connecters and never thought of using the 50 amp dog bone. Thanks for the idea! Jim
30 amp cord to 50 amp outlet. urnmor Batteries, Univolts, Converters & Inverters 20 10-21-2011 12:55 PM
Simple Q: 30 amp RV cord to 15 amp wall unit.. Shmeter Electrical - Systems, Generators, Batteries & Solar 2 07-17-2011 07:55 AM
30 amp power cord trouble davidz71 Electrical - Systems, Generators, Batteries & Solar 1 03-12-2003 05:29 PM
