Old 04-15-2011, 07:14 PM   #15
Ottawa , ON
Originally Posted by Pinchy View Post
(where my wanes coating is)
I think you mean wainscoting (rhymes with sailboating)
Old 05-28-2011, 02:58 PM   #16
1974 Argosy 24
New Orleans , Louisiana
Pinchy, I really like what you've done with the front seating area! This is exactly what I would like to do in my '74 24-footer. Any chance you have some plans you might be willing to share?
Lauren
lacraig819 is offline   Reply With Quote
Old 05-29-2011, 07:56 AM   #17
1978 Argosy 30
Hope , Maine
Lauren,
Don't really have plans...but these pics will reveal really how simple it is.
Some bullet points:
The angle iron is self-tap screw bolted into the frame members for obvious rigidity.
There five of them - two on the flanks - two small ones on the corners (it doesn't matter if they follow "the bend" in the trailer or not) and one along the center under the main front window.
2x4's bolted to them.
Plywood flanks not screwed down to allow access to pump, H2O tank, etc.
We are still making curtains - AND - the rear backrest will be simply a mattress topper with cover that is rolled up during the day. At night, it will unroll to cover the seams the cushions create.
The table column I think I picked up at Hamilton Marine - or any search at a marine supply will render a telescoping table column. That was the most expensive of the whole plan... I think about $200 or so...
Let me know if you have questions.
ID:	130976   Click image for larger version
ID:	130978   Click image for larger version
ID:	130980   Click image for larger version
Pinchy is offline   Reply With Quote
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
New 30 amp plug needed ck21084 Batteries, Univolts, Converters & Inverters 21 09-29-2016 11:42 AM
Anyone have a wiring diagram for '75 excella? MonaxLisa Electrical - Systems, Generators, Batteries & Solar 13 03-27-2011 12:54 PM
Question on using 50 amp sevice RLS Electrical - Systems, Generators, Batteries & Solar 16 02-04-2011 01:14 PM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 07:25 AM
