04-27-2009, 03:15 PM
Stockbridge
, Georgia
50 amp bussman fuse
I just bought a '79 31' & (I am new to the 'streaming scene i need a fuse from the front panel. Its a 50 amp 32v green midget fuse, kinda' like the glass ones but not. I don't think its a fast blowing fuse but a slow blow. I can't seem to find one anywhere, or maybe a replacement type for it?
Help pleease
04-27-2009, 03:28 PM
Remember, Safety Third
Catfish Corners
, Georgia
Greetings from just down the road. Did I read that right? 32 Volt, 50 amp? That's pretty hefty fuse.
04-27-2009, 03:34 PM
Stockbridge
, Georgia
Hey Jim,
yep, it reads: Buss ABU 50 & on the other end it reads 32V. I agree it seems to be pretty stout, but there are 3 in a row on the panel. 1 1/2" long
04-27-2009, 03:43 PM
Catfish Corners
, Georgia
How about maybe 12v, 32v max or something? I don't know what would be 32v on the Airstream. What does this fuse power?
04-27-2009, 03:53 PM
1978 25' Tradewind
San Bernardino
These fuses are for protecting the battery + and - cables. They are 32v 50 amp explosive protected fuses. The voltage rating means that it can be used in applications up to 32 volt power. They can be difficult to find, I blew one once and it took two days to find a place that had them. It was an air condition repair show.
04-27-2009, 03:56 PM
Corona
Help pleease
That physical size comes in 35, 40 and 50 amps.
You are correct, that it is indeed a 32 volt DC fuse.
Airstream has used them for years.
04-27-2009, 04:02 PM
Stockbridge
, Georgia
It's on the panel above my univolt, I think it's for my battery. I think I'll try a new batt. before I find & put the fuse in.
04-27-2009, 04:23 PM
Stockbridge
, Georgia
Thanks to everyone for your help, one day I hope to return the favor,
Michael
04-27-2009, 04:41 PM
1979 23' Safari
1954 29' Liner
Orange
I have found those fuses at a marine supply store, such as Anchor Marine in Anaheim, CA
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
04-27-2009, 04:47 PM
Catfish Corners
, Georgia
I guess I need to go look at my Univolt fuse panel. Are you saying that this fuse is on that board between the baord and the positive cable to the battery? If that's the case, then the fuse is a 12v, but is capable of being used in a circuit up to 32 v? Did I get it right?
04-27-2009, 05:33 PM
Corona
Jim.
Yes, you got it right.
04-27-2009, 05:42 PM
1993 34' Excella
Estancia
, New Mexico
My Univolt had some 40 amp glass fuses I was not able to find. I was advised to try audio shops. No luck.What I did find was a automatic resetting thermal breaker that fits right into the fuse receptacle been OK ever since.
But, that also defeats the purpose of the fuse if when it resets it creates a dangerous situation.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Fuse questions
63air |
Batteries, Univolts, Converters & Inverters |
2 |
08-13-2007 09:28 AM |
fuse help !!!!
Shellie |
Electrical - Systems, Generators, Batteries & Solar |
3 |
05-17-2006 06:24 PM |
Fuse Box??
dye904 |
4 |
10-27-2005 12:48 PM |
'78 Tradewind labeled fuse box pics & questions
BOBHASTINGS |
20 |
06-15-2005 06:33 PM |
Fuse panel
bluebonnet |
7 |
08-15-2004 10:42 AM |
