Old 04-01-2009, 07:43 PM   #1
bertro's Avatar
1971 23' Safari
Groveport , Ohio
3rd try battery ? Do I have the worm
My, I'll make it short this time. I kept my 27 series lifeline in all winter and kept a 12.84-12.94 charge with a disconnect switch. I would plug in to shore power when spending time pumping watts through the sound system thinking about the first trip of spring. Should I deplete the battery charge from time to time and recharge to get better battery life. Robert
bertro is offline   Reply With Quote
Old 04-01-2009, 10:28 PM   #2
1975 29' Ambassador
Reno , Nevada
If it was NiCd then a deplete recharge might be a good thing, but a lead acid, such as an AGM doesn't like it.
It is a good idea to 'exercise' the battery regularly but only in taking it down to about 12.2 to 12.4 volts before a proper recharge.
The AGM has a low internal discharge rate so it can survive a few months without a maintenance charge. Letting one sit, though, is not the optimum for longest life. You should use a battery maintainer that will keep a proper float voltage and provide some desulfation technique during storage.
Any 2nd or 3rd generation airstreams bertro Airstream History 2 12-20-2008 09:30 PM
3rd battery for less than 10 bucks john hd Batteries, Univolts, Converters & Inverters 18 09-17-2007 08:34 PM
New Worm? maxandgeorgia Off Topic Forum 13 02-03-2006 01:05 PM
AirstreamForums 3rd Anniversary ALANSD Our Community 11 01-29-2005 08:55 PM
Suburban 3rd seat TomW On The Road... 1 01-21-2004 06:04 PM
