Old 03-01-2003, 11:37 AM   #1
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Lightbulb 3rd battery for less than 10 bucks
hey gang,
here is my latest project.
i have a 2500 silverado 4x4 with the "snow plow prep package" it has a 2nd battery with a relay installed from the factory.
i decided to put it to use finally, to have more reserve battery power when boondocking.
the materials from ace hardware, less than ten bucks.
Old 03-01-2003, 11:39 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
under the hood...
this is the placement of the batteries
Old 03-01-2003, 11:40 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
relay
and this is the relay
Name:	aux batt & relay.jpg
Old 03-01-2003, 11:41 AM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
wire
running 10 ga wire
Old 03-01-2003, 11:44 AM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
fuse box terminations
this is a pic of the fuse box termination and the no longer needed 30 amp fuse.
the aux battery is fused with a 40 mega fuse.
Old 03-01-2003, 11:46 AM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
install complete
new wire terminated, old fuse removed
Old 03-01-2003, 11:48 AM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Cool bam! done!
testing brakes and interior lights with no batteries installed in the trailer.
john
Old 03-02-2003, 08:29 PM   #8
Thumbs up Nice Job!!
John,
Nice job!! Are you going to put in a deep cycle after this one dies of old age?
John
John is offline   Reply With Quote
Old 03-02-2003, 08:43 PM   #9
Raptorrider2001's Avatar
Richardson , Texas
Images: 14
Lightbulb
John HD-A little off the subject, but what is that thingy on your electric jack? I might need one for my Airstream.
I have a Duramax with 2 batteries and am going to see if mine has that relay also. Great idea!
'99 25' Safari
2 Honda 2000i generators
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 03-02-2003, 11:59 PM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Question
john
hadn't thought about that, i have "regular marine" batterys in the trailer. i'll probally replace it with one like that with the exception of needing a side terminal design. all four are 650 cca.
raptorider,
the thingy is my flag pole bracket.
a second battery on a duramax is most likely used for the glow plugs and starting. unlike mine.
you could add a battery isolator, but i don't think it would help in your case because your batteries are wired in parallel to the starter.
a duramax would by design, already supply current to the 2nd post in the fuse box by both batteries.
john
Old 03-03-2003, 06:37 AM   #11
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I did roughly the same thing....
I just came off the + post of the 2nd battery and ran it through a small 30 amp breaker, then out the existing wiring harness to the trailer receptacle. Mine also has the isolation relay. On thing I am wondering, if one were to run both the trailer battery and truck aux battery down, what would the draw be on the main truck battery when attempting to start the truck. That relay energizes when the ignition is on, to facilitate charging the 2nd battery. I would guess that 40+ feet of #10 would limit the current. Has anyone calculated the voltage drop?
John, better get that rear license plate taken care of before the cops see it!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-03-2003, 06:52 AM   #12
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Thingy on jack
That is a flag holder. A previous owner was undoubtedly an officer in WBCCI; probably a Past President. The 3 flags displayed are US, Region or Unit, and Officer's flag.
John W. Irwin
WBCCI #9632
Old 03-03-2003, 06:58 AM   #13
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
resistance
pick
if the second battery was run down and you turned the key on the good battery would start to charge it. kinda like jumpstarting a dead battery. but when you turn the key to start the resistance of the battery would be much more than that of the starter. this would mean that most, if not almost all of the current from the good battery would go to the starter.
i'll have to try it and see!
as for the resistance of 40 feet of #10, i'll have to look that up.
i'll get my plate fixed asap! don't want to get hassled by the man!
john
Old 06-02-2004, 12:02 PM   #14
jaco's Avatar
Hey JohnHD it has been a year since this thread. How did it all work out? Any updates or problems encountered ?
jaco is offline   Reply With Quote
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 05:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
