03-07-2011, 11:55 AM
SantaFeBob
2022 20' Basecamp
Santa Fe
, New Mexico
30 Amp to 15 Amp Adapter to House Power Question
Good afternoon.
I'm off on a trip this summer and will be leaving my 2010 27' Flying Cloud at a relative's home for a week. For clarification (not being an electrician): 1. Can I plug in my 30 Amp power cord into a 15 Amp adapter (like I see at Camping World) and then directly into the 3-prong house plug? Is there any risk here? Probably run the 30 Amp power cord about 40 feet (with my 30 Amp extension cord). 2. I'm only interested in running the internal Airstream lights at night and using the refrigerator. 3. Do I turn the power breaker on or off?
Apologize if the questions are simple; they're just not clear to me; and I don't want to blow anything.
Thanks much!!
03-07-2011, 11:59 AM
2002 25' Safari
Dewey
The only risk would be if you exceeded 15 amps. With just the converter and fridge you should be fine. Running the air conditioner would not be good.
Richard
03-07-2011, 12:01 PM
x
XXXX
, XXXX
Bob that will work just fine. you won't be able to run the A/C that way but lights and fridge are O.K. No you don't need to turn off any breakers before plugging in.
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
What you are describing is perfectly ok. As you are not planning to run your air conditioner, you should have no problem. Just plug in and be happy.
And welcome to the Forums!
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
03-07-2011, 12:13 PM
Wise Elder
2010 30' Classic
South of the river
Originally Posted by Steamboatbob
Good afternoon.
Yes. People do it all the time.
There are no risks per se but there are a few things to be aware of that can be frustrating if you are unprepared to deal with them:
1. Some of the cube shaped adapters (as opposed to the dogbone shaped adapters that have a 12" or so cord between the ends) are too large to physically fit around the outdoor outlet covers on some outlets.
2. The weight of the 30 amp cord and the adapter may be enough to pull the plug out of the outlet unless you figure out a way to support it. This is particularly a problem if the outlet is a little higher than the usual height.
3. Since most 15 amp outlets have GFCIs while most 30 amp outlets do not, there is a chance that you will find that you have a wiring problem that causes the GFCI to trip that you didn't know about before. So, if possible, try plugging into a 15 amp outlet with a GFCI at home or the next time you're at a campground, to be sure that the wiring in your trailer doesn't trip the GFCI.
Good. As long as you don't try to run the air conditioning or plug in a portable electric heater you should be OK.
On.
03-07-2011, 12:14 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Greetings from the Florida Panhandle
I agree with the others. As long as you don't run the air conditioner or heat pump, it will be fine. I have done exactly this many times myself.
I also noticed that this is your first post. Welcome to the Forums. We're glad to have you with us.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-07-2011, 12:23 PM
2022 23' Flying Cloud
2006 28' Safari SE
Gold Beach
, Oregon
I had the exact same question this morning and am glad to see it answered so well. Thank you.
Idmtman
2022 Flying Cloud 23FB (Yalla)
2010 Toyota Tundra 4x4
TAC: ID-1
03-07-2011, 09:08 PM
SantaFeBob
2022 20' Basecamp
Santa Fe
, New Mexico
Thanks to everyone for their assistance. This is incredibly helpful. Definitely appreciate the guidance.
Best regards,
03-07-2011, 09:13 PM
2006 19' Safari SE
Tucson
Don't run the microwave either if you have one. Your AS will be perfectly happy as long as you don't try to run any of the big-draw items mentioned above...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
03-07-2011, 09:22 PM
Airstreamer
2012 27' FB International
Bellevue
My Airstream is parked right out front right now, plugged right into our house with the same setup you described. The fridge is on as well as a small space heater.
{blog} ★ Just 5 More Minutes to Enjoy Non-Stop Outdoor Adventures and Culinary Discoveries in the Northwest with our Airstream ★Blogger for GoRVing.com
03-07-2011, 09:26 PM
Trabuco Canyon
In addition to whats posted above regarding 15 amp circuits, if you can find a 20 amp circuit you may be able to run the air conditioner. On my house there are 20 amp breakers labeled for garbage disposal, double outlet for furnace, washer, dryer, dishwasher, garage door opener, etc. and some may not be in use. My trailer's 11K BTU AC runs fine on a 20 amp circuit with normal voltage in the trailer. It will not run on a 15 amp circuit.
03-07-2011, 10:25 PM
1989 34.5' Airstream 345
Cleveland
, Tennessee
Please note that there are 30 amp to 20 amp adapters out there. Using one of these with a 12 gauge wire extension cord will allow you to use A/C in the summer on a 20 amp circuit. Just a thought if you haven't gone out to buy adapter & cord yet.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
03-12-2011, 12:55 PM
San Luis Obispo
I'll tack my question onto this thread...
I'm running my 30 amp cord from my '73 overlander through an adapter to the 15 or 20 amp circuit on the house.
I havnt had any problems until recently, when the plastic housing where the prongs for the 30 amp plug are has started to corrode. the one prong seems to be corroding and the plastic seems to be melting. When I noticed this I unplugged it and havnt used shore power since.
My question is can I go ahead and replace the 30 amp cord as well as the adapter and trust it to work like it always has, with the assumption that this was a flaw that replacement parts will fix, or is there a contributing factor that I dont know about that causes this sort of issue to happen?
03-12-2011, 01:12 PM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
30A connection
Chances are the plug blade got dirty and poor contact created excessive heat to melt the plug.
It is good preventive maintenance to clean the plug blades with sandpaper if they show any sign of corroding.
Good contact is a must or it will get hot with the extra resistance.
Dave
03-12-2011, 01:43 PM
on the hunt
riverton
, Kansas
I did this as well before installing a bigger 30amp plug.
It did work OK but the lead did get hot at both ends at the wall and the shore power plug. would suggest setting it up on something so it not just laying on the floor or against the wall and keep an eye on it.
03-13-2011, 07:53 PM
Wise Elder
2010 30' Classic
South of the river
It's common for them to fail and melt.
As noted by others it may be corrosion either on the adapter or the plug. Contact grease or the more readily available (in home centers) grease for aluminum wires might help. Or, it may be that the plug blades are not making sufficiently secure contact with the wires.
In any case there's nothing wrong the with the cord. You just need to replace the plug on the end and perhaps the adapter.
03-13-2011, 11:50 PM
San Luis Obispo
thanks for the help. after looking closer i see that i definitely need to replace the plug, and while the adapter appears fine the heat seems to have fused it pretty tight to the extension cord, so rather than force those apart i will replace them too.
03-14-2011, 07:23 AM
1993 34' Excella
Estancia
, New Mexico
The thing about running an AC is it may run but if it does not have adequate amperage I have been told can be damaged. What is enough amps depends on the model and BTUs.
03-14-2011, 10:30 AM
Wise Elder
2010 30' Classic
South of the river
While commonly heard and repeated I do not believe that voltage drop actually leads to air conditioner failure. I believe that RV dealers and techs like to blame voltage drop for air conditioner failures that are caused by defective materials and workmanship, and so the myth never dies.
I have offered many times to organize an event where we get a used air conditioner from an RV boneyard and try to make it fail by dropping the voltage. I don't think it can be done.
03-14-2011, 11:03 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I plug ours into a 20 amp anytime I am working on it in the driveway. I have been known to run the AC and/or heat pump without any problems. That said, if it is really hot, the AC will draw enough to trip the house breaker for the circuit.
Where we store our unit, there are 15 amp outlets, and most of us plug in with an adapter in order to keep the batteries charged.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
