Old 11-12-2014, 12:55 PM   #1
Natty Lite's Avatar
Mandeville , Alabama
30 amp hook up to garage
Can I hook up to my garage that runs six fluorescent fixtures?
It now has a 20 amp breaker which I will replace with a 30 amp breaker and add an outlet that has a 30 amp plug!
Natty Lite is offline   Reply With Quote
Old 11-12-2014, 01:06 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
You need to look at the romex wiring and see if it is large enough for 30 amp.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-12-2014, 01:08 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
NO
You can not just change a breaker to 30 amps. Breakers are rated for the size of the wire that feed it. If you want 30 amps to the new outlet either run a new #10 line to it.
I have a 30 amp plug on the 20 line but know I will never use the AC in the trailer while plugged into it. It is just for battery charging and frig before we go out.
If you do put in a receptacle put a switch before it and use the switch to turn the receptacle off before connection and disconnecting. Failure to do this will cause an arc across the blades of the plug and receptacle and shorten the life of both.
2004 Excursion 4x4
Old 11-12-2014, 01:08 PM   #4
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Don't put in a 30 amp breaker unless you change the wiring. The reason it has a twenty amp breaker is to protect the wiring that is installed. A 30 amp outlet and breaker will require 10 gauge wiring to be run. A twenty amp circuit only uses twelve gauge wire, which is too small for 30 amps of current.
That's a very simplified explanation, but it will keep you from burning down your house...
Now, if you want to get an adapter and plug it into a twenty amp outlet, you'll be fine until you turn on enough appliances to draw more than twenty amps of current, at which point your breaker will trip. I plug mine into a regular old fifteen amp wall outlet all the time, which will run your refrigerator, or your a/c unit, but usually not both without tripping the breaker...
-Red, simplifying the electrical world since 1962...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 11-12-2014, 01:13 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
An important question is "Why do you want to plug into this circuit in the garage?"
If your answer is "to charge the batteries, run the refrigerator and keep the lights on" or something along those lines, you'll be fine with using a 15A-to-30A adapter and plugging into the regular receptacle that's already there. If you want to run the trailer's AC, pay heed to the posts above.
If you call an electrician to put in an electrical circuit, make SURE the electrician understands you want a 30A 120V RV circuit (the receptacle is called a NEMA TT-30R). Get this agreement in a written form if possible, and check the voltage on the installed receptacle before you plug your Airstream in. Some electricians seem to think RVs are supposed to use a 240V dryer socket...
David
Old 11-12-2014, 01:16 PM   #6
1987 25' Sovereign
Oregon , Ohio
You could achieve the same thing by changing just the plug and not the breaker to 30 amp 110 volt.
msmcv51 is offline   Reply With Quote
Old 11-12-2014, 01:26 PM   #7
Panama Red's Avatar
Obrien , Florida
Yeah... Now you're just making it TOO easy... Wink wink, nudge nudge.
-Red, overlooking the obvious since 1962...
Old 11-12-2014, 01:57 PM   #8
dznf0g's Avatar
Oswego , Illinois
Attached garage? I had space in my main breaker box for the house and ran a new 30A circuit to the garage from the basement. The run was only about 30 feet total from the basement and up through the garage/laundry room wall. $100 and 2 hours....done!
-Rich-
Old 11-12-2014, 02:12 PM   #9
2007 22' International CCD
Installed RV plug and breaker in power box just inside son's garage door in Alabama. AS cable under the door, plug in, flip breaker, and we're in business.
Took longer to mount a 2x4 old work box in the wall under his panel than it did to wire it. Neat, tidy and kid proof.
Big box stores carry the parts. Be sure to wire with 10 gauge wire with ground and get it connected right.
Breaker is left off unless we are plugged in. YMMV.
KE4GNK/AE
Old 11-12-2014, 03:24 PM   #10
Natty Lite's Avatar
Thanks guys,
I will run new wiring and make a new 30 amp breaker dedicated to the RV, so I can run AC!!
Old 11-12-2014, 03:59 PM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I had an electrician put in a 50 amp rv plug and breaker.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-13-2014, 10:48 AM   #12
2010 22' Sport
Boise , Idaho
That's exactly how I did it. I was building a new shop just after we bought our AS so I did a 20 amp circuit for the lights and stuff and a 30 amp circuit for "Wally".
baldwin6601 is offline   Reply With Quote
Old 11-13-2014, 11:16 AM   #13
KatieMacSC
katherynhart's Avatar
1975 31' Sovereign
Morganton , katherynhartzell
I bought a male 20 to female 30 adapter at Amazon. I have the fridge on gas, don't run A/C. It just flipped the house breaker one time, so now I watch it.
katherynhart is offline   Reply With Quote
Old 11-13-2014, 12:29 PM   #14
m.hony's Avatar
2013 30' Classic
I did that before I had the new breaker, wiring, and receptacle installed.
TAC #MS-10
Airforums #70955
2004 Airstream 30' S/O, Class A, 34,200 miles, Beautiful & Garage Kept - $38,900 eBay Watch Airstreams on eBay 0 11-07-2011 07:00 AM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
I'm past the hook, now I'm in with the line & sinker LI Pets Member Introductions 15 09-16-2006 07:13 PM
Battery Location & Hook Up achip Batteries, Univolts, Converters & Inverters 0 06-28-2006 08:12 AM
