03-02-2015, 05:09 PM
2013 30' International
Kennewick
30 amp fuses pop
When I plug in with 110volt power the two 30 amp fuses pop. Looks like they are related to the 20 amp breaker for the converter. I have a 30 foot international 2013 with 50 amp.
03-02-2015, 06:36 PM
Mantua
, Ohio
Are you plugging into 120 or 240? Peace,jim
03-02-2015, 07:47 PM
Kennewick
I first plugged into 240 and that popped the 20 amp breaker and blow both 30 amp fuses. I then wired a new 110 volt 30 amp receptacle for the coach in my shop. I replaced the two 30 amp fuses and plugged it into the new receptacle and it only blows the 30 amp fuses. The 20 amp breaker does not trip
03-02-2015, 07:59 PM
2016 30' Classic
Hinckley
, Ohio
RV plugs are 120 volts! You are plugging into a welder or range box that's 220 volts. Those breaker are suppose to blow. You over loaded them.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
03-02-2015, 08:00 PM
King of the Zebra Speedo
Obrien
Betting you blew the rectifier (your twelve volt charger/supply) when you plugged it into the 240... Nothing definite, but when you shove the 240 into the 120 input, nothing good happens.
Hoping you didn't have anything plugged into the 120 volt system. Nothing out there likes 120vAC shoved in on the neutral line. Wish I could be more positive here. Hope it works out different than what I'm saying...
-Red, checking in to follow the thread...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
03-02-2015, 09:08 PM
1974 Argosy 26
Morrill
, Nebraska
Unplug the converter and see what happens. As long as the other 120 volt devices were not turned on. You may be OK.
03-03-2015, 09:31 AM
Kennewick
Nothing was plugged in so I am good there. I will buy a new Power max pm4b-60 converter. This should solve the battery issues I have beefing reading about also.
03-03-2015, 11:15 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
If you plugged into 220 the converter should have blown, mine did. Had the garage wired by a well known licensed electrician, told them four times - this is NOT a 220 line. Well they wired it as such - blew the converter and smoke filled the trailer. $1,240.00 later they had purchased me a new converter, new blue ray and paid my mileage to the dealer in addtion
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
03-03-2015, 11:50 AM
1955 22' Safari
Laredo
Similar problem but less severe consequences for me. New custom home in which I requested a 110 volt 30 amp "RV" outlet in the garage. Of course the electricians wired it as 220. First time I plugged in my Bambi II it blew the Univolt but it was planned to be replaced anyway. No damage to anything else.
