Old 10-21-2011, 07:11 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
30 amp cord to 50 amp outlet.
Our camp site this weekend has a 50 amp hook up however the Flying Cloud is designed for 30 amps. I was wondering if there is a cord that will allow me to convert the 30 amp cord to 50 amps and if so is there any potential damage to the electrical system?
John
urnmor is offline   Reply With Quote
Old 10-21-2011, 07:27 AM   #2
Gainesville , Florida
An adapter can be had from most rv suppliers. Sometimes the campgrounds have them available. No problems when using the adapter. jim
Old 10-21-2011, 07:28 AM   #3
dznf0g's Avatar
Oswego , Illinois
Worldwide Merchandise Company - 50 Amp Male to 30 Amp Female Adapter with Handle - Electrical Adapters - Camping World
Like this one
Old 10-21-2011, 07:30 AM   #4
NoMoSOBs's Avatar
1998 30' Excella 1000
Aylett , Virginia
Images: 14
I found one in Walmart yesterday.
John T.
TAC VA-16
NoMoSOBs is offline   Reply With Quote
Old 10-21-2011, 07:41 AM   #5
WBCCI9898's Avatar
1997 34' Limited
Oyster Bed Bridge , Prince Edward Island
got ours at walmart....cheapest one i found. We ran into that problem in florida couple winters ago.
WBCCI9898 is offline   Reply With Quote
Old 10-21-2011, 08:36 AM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Does the 30 amp adaptor include a 30 amp breaker? if not your wire could draw more than it's rating.
Old 10-21-2011, 08:46 AM   #7
dznf0g's Avatar
Oswego , Illinois
No it won't. If you try to draw more than 30 amps, the main breaker in the AS will trip.
Old 10-21-2011, 08:56 AM   #8
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Web site that compares 30 amp and 50 amp service: RV Electric
Old 10-21-2011, 09:13 AM   #9
dznf0g's Avatar
Oswego , Illinois
I'm not sure if these two posters are concerned about the 240V thing...but ALL these dogbone adapters have one of the 120V legs dead. The prong is there but it is not connected electrically to anything. So it is impossible to get 240V to your 30 amp single leg trailer out of the 50 amp outlet with a dogbone designed and used exclusively to adapt a 30 amp rv to a 50 amp RV outlet
Old 10-21-2011, 10:15 AM   #10
urnmor's Avatar
Berlin , Maryland
My thanks to all. Lot to think about however I probably couldn't run my AC off it so I will pack generators. I was just looking for the easy way out.
Old 10-21-2011, 10:40 AM   #11
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You should be able to easily run your AC off of 50-amp service with a 50A-to-30A dogbone adapter. 50A RV service is has 2 120v/50A lines, so whichever one the dogbone taps into should provide more power to your Airstream than a 30A connection would.
— David
DKB_SATX is online now   Reply With Quote
Old 10-21-2011, 10:44 AM   #12
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
John,
Your AC will run fine, usually, whether connected to a 30 or 50 (using the dogbone). We do it all the time. What I'd like is a 30-to-30 dogbone for those *odd* boxes which don't easily allow my surge protector to pull in solidly. Just can't seem to find a pre-made one on the market.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 10-21-2011, 10:55 AM   #13
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by gheuer View Post
John,
It would be over kill. However, you can buy a 25 foot 30 amp extension cord (~$30) for what seems to be less than the cost of male and female do-it-yourself fittings.
Ken
Old 10-21-2011, 10:57 AM   #14
dznf0g's Avatar
Oswego , Illinois
Greg, what's the issue? Is yours the surgeguard portable unit? And what are you trying to find commercially?
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
Simple Q: 30 amp RV cord to 15 amp wall unit.. Shmeter Electrical - Systems, Generators, Batteries & Solar 2 07-17-2011 07:55 AM
30 amp plug into 50 amp welder outlet? hipsters Electrical - Systems, Generators, Batteries & Solar 17 07-06-2011 03:56 PM
Question on using 50 amp sevice RLS Electrical - Systems, Generators, Batteries & Solar 16 02-04-2011 01:14 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
