Old 08-26-2011, 10:46 AM   #15
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by 68 Overlander View Post
Jammer is correct. I get a call EVERY day from somebody that did it. Its almost always in this order.. Converter 99% of the time is gone. Microwave about 50% of the time and AC about 25%. Sometimes all three.
It is often electricians or a "friend" that did it. That plug does look like 240.
It looks kinda like an old-style dryer outlet, except for that "30A 125V" that's cast into it.
— David
Old 08-26-2011, 11:33 AM   #16
Southwestern , Ohio
Yeah, it would be good if people would pay attention to what it says right on the outlet! The trouble is that in ordinary house wiring when you are dealing with circuits over 20 A they are almost always 240 V, which only makes sense. The 120 V 30A circuit is almost unique to RVs.
Nuvite-F is offline   Reply With Quote
Old 09-01-2011, 11:05 AM   #17
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
The converter (Intellipower 9260C) is working, Fridge is okay. Only the A/c seems to be a problem. It is an Armstrong 14. The blower runs fine. Just the compressor does not kick on. I believe there is some kind of breaker or resetting switch that protects the compressor. There are some relay capacitors that look burnt. Any ideas?
tcrum is offline   Reply With Quote
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
3 Amp Availability gaylejoe WBCCI Forum 27 08-06-2011 03:38 PM
Simple Q: 30 amp RV cord to 15 amp wall unit.. Shmeter Electrical - Systems, Generators, Batteries & Solar 2 07-17-2011 07:55 AM
30 amp plug into 50 amp welder outlet? hipsters Electrical - Systems, Generators, Batteries & Solar 17 07-06-2011 03:56 PM
Question on using 50 amp sevice RLS Electrical - Systems, Generators, Batteries & Solar 16 02-04-2011 01:14 PM
