Old 06-27-2017, 09:32 AM   #57
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Everyone has personal experience and testing in their professional lives in shade tree and disciplined test. That experience cannot be discounted or discouraged. I have used the hammer crimp with proper tool to make lots of welding leads. Because exposed to weather, I hot dipped in solder pot... never a failure as long as secured against vibrations, or allowed to electrolysis...
I have also desired golf carts, without hot-potting, just hammer crimp... still running after 4 years of extensive use.
I should note.. most wiring I do is "overkill"...bigger wire than "minimally needed"... and so far no failure in that area.. except trying to get it to fit.
As mentioned above, a "copper" strap will do nicely and if it discolors you can see without guessing.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-27-2017, 12:10 PM   #58
2004 22' Safari
Albuquerque , New Mexico
Originally Posted by GCinSC2 View Post
Bob,
It's a sad day when you don't learn something.
I have associates degree in EET but back then we were carrying slide rules for math.
My specialty is 37 years in the clutch industry.
Gary
My slide rule still works!
My HP 50 has dead batteries...
Silver.Sanctuary is offline   Reply With Quote
Old 06-27-2017, 12:48 PM   #59
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
My Pickett model N-500-T with leather case and manual is on standby in the event of zombie apocalypse.
Also fun to show the "app" crowd a tool that helped put us in outer space.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 06-27-2017, 02:03 PM   #60
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
When I graduated with an engineering degree, for our final test we could bring two items to help in the test.
1- a sheet of paper with relevant formulas
2- a bucket of cold water to cool down the slide rule! There were a lot of questions....
Troutboy
Troutboy is offline   Reply With Quote
Old 06-27-2017, 02:47 PM   #61
2007 22' International CCD
2 inverters in 2 mos., both SMOKE!
One student famously used scratch paper and a book of 10-place log tables instead of saslide rule. Looked like a paper blizzard when he took his finals...
Still have a working HP Reverse Polish Notation system calculator. It's great fun to hand to someone expecting a "standard" calculator...and the 'enter' key adds to the fun.
Nerd humour at its best...
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 06-28-2017, 09:26 AM   #62
1987 29' Airstream 290
Los Angeles , California
Originally Posted by lsbrodsky View Post
GinaP,
I have been thinking about all of these posts. The forum is a great resource and everyone tries to be helpful, but sometimes the advice is spot on, other times not so much.
People seem to have jumped on the hammer crimp as the root cause. Look hammer crimps are the inexpensive route but they are not necessarily bad. If the crimp is bad, that will be the point of high resistance and should be the hottest spot. In the one picture it appears that the insulation around the crimp is not getting as hot as the red tape next to it.
An earlier post suggested the red tape as the culprit. Another earlier post suggested an IR temp measurement. Clearly you should not be using your system until you get to the cause so wherever you are you should purchase or borrow an IR temp gauge. I have two; they are inexpensive. Energize your system and check the temps looking for the real hot spot.
To me it looks like the red tape was burning and that heat spread a bit. I do not see any evidence of that kind of heat on the insulation adjacent to the crimp, on either side. Nevertheless, it would appear that the real fix, now, is a new wire, new connectors, in that location. Don't reject the idea of a hammer crimp if you are near someone who can do that for you.
Larry
@lsbrodsky: Thank you for your reply! I'll have an expert look at it to diagnose.
GinaParmesan is offline   Reply With Quote
Old 06-28-2017, 09:28 AM   #63
@cwf: Thank you! I think having someone dissect the cable will tell the tale.
Old 06-28-2017, 07:39 PM   #64
2016 19' Flying Cloud
Portland , Oregon
/overkill
Snowy is offline   Reply With Quote
Old 06-28-2017, 07:58 PM   #65
Seattle , USA
Perfect install or not, I simply can't believe that some people (not referring to the OP) install these things under their BEDS.
That's gotta be a bad way to go.
RareStream is offline   Reply With Quote
Old 06-28-2017, 08:05 PM   #66
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'm a B-School guy. HP17B2
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-28-2017, 08:41 PM   #67
Rivet What a day, what a day
Hello all,
First of all, thank you each and every one for contributing your ideas, experience and concern for my safety. After what I learned today, I'm deeply grateful I didn't have a fire.
The installer's diagnosis from afar is that this is my fault. I must be drawing too much power, which is overheating the fuse, and the hot fuse is what was burning the end of the cable. They estimated I must be using 800-1,200 amps DC with surges possibly 9,000 to 12,000 Watts to cause this problem. They also said the 400A ANL fuse was cheap and I should've gotten a class T fuse anyway.
I had two separate outfits look at the problem today. The RV repair shop said it was either a loose fitting or a bad crimp. They couldn't fit us in as a "drive up" so we went to a shop that specializes in electrical work for basically anything that moves. They confirmed it was a bad crimp and they replaced both wires connecting to the battery switch, and the fuse block. They checked my draw while running the water kettle, a/c etc. too and said everything is good in that department. So there’s that.
They also said that the same issue will occur at the next bad crimp if there is one, so I’m having the rest of the crimps inspected on Monday.
PS, loving the nerd humor above!
PPS, the crimps on the new cables were done with an 8-way hydraulic crimper.
Name:	Screen Shot 2017-06-28 at 9.36.37 PM.png
Old 06-28-2017, 08:45 PM   #68
Troutboy's Avatar
Parker , Colorado
GinaP, thanks for sharing what you found out, helps us all learn. Sorry you are going through this, but glad you found issue and are safe.... please keep us update, and I hope the rest of the crimps are rock solid.
Troutboy
Old 06-28-2017, 08:52 PM   #69
I never thought I'd be using the word "crimp" this much. I had no idea what the hell a crimp was until this past Sunday. The more you know, the more you know you don't know... something like that anyway.
Old 06-29-2017, 10:28 AM   #70
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Well, if you *were* pulling 1,200 A into the Victron, it's one heck of a fine inverter. You got a 12 KW unit for the price of a 3KW ... lucky you. I guess that the 400A fuse being in there and not blowing was some sort of fluke. You also got some really amazing batteries to be able to source 1,200 A for as long as you did. Again, a really sharp deal on your part.
Based on what you have found (smoke) and their nonsense, I would not trust anything done by the original installer. Have somebody good go over the whole install. If that means waiting a week for a slot, wait. Also be ready to (happily) pay them a couple hundred bucks. It's not their fault it was messed up. If you get away for less, that's fine as well.
Smoke, Smoke Everywhere ncbambi 2008 Safari SE 14 07-25-2010 07:28 PM
THE ADVENTURE BEGINS - 6 mos Full Time Phantom On The Road... 3 10-17-2008 06:18 PM
Voltage Inverters mcostanzo Electrical - Systems, Generators, Batteries & Solar 12 08-01-2006 11:37 PM
Inverters again ! Tinsel Loaf Electrical - Systems, Generators, Batteries & Solar 8 08-22-2004 08:22 AM
