Old 07-11-2015, 04:22 PM   #1
2014 23' FB Flying Cloud
Mill Valley , Left Coast
14 FC FB Wire Size
Unit is a 2014 23' Flying Cloud forward bedroom. I am not able to look at my unit wondering if someone could check this out for me.
I need to know the size of the main battery cables, I seem to remember that they are about a #6 or#4 AWG.
Thanks!
J.B.
jbxx is offline   Reply With Quote
Old 07-11-2015, 09:39 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
I remove these cables on a regular basis when I install solar charging systems with new AGM or lithium batteries.
Airstream generally uses 6 AWG cables from the batteries to the bus bars and then back to the DC fuse panel and converter.
If you have the factory WFCO inverter, there will be a second set of cables from the batteries to the inverter that are generally 4AWG.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-12-2015, 05:31 PM   #3
Tnx!
J.B.
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
What size breaker for 8 gauge wire? guy99 Electrical - Systems, Generators, Batteries & Solar 7 11-20-2005 12:24 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
