Old 07-18-2013, 10:16 AM   #1
1974 27' Overlander
rochester , Michigan
12volt system
My 1974 overlander is only getting power when plugged in. I had the battery checked and it is fine(95% charge).Any idea of where to look next? Thanks
freerider is offline   Reply With Quote
Old 07-18-2013, 11:06 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Make sure the battery cables are installed securely at both ends, check for fuses in the current path from the batteries to the fuse block (making sure the fuses are good AND the connections are good.)
Do you have an old 12V converter with built-in fuses? Or do you have a separate fuse block?
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 07-18-2013, 11:08 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
On the theory of "check the easy things first," make sure the battery disconnect is set to "on" or "use" (whichever label it uses for the power-on position).
Then, if that doesn't solve the problem, check the fuse for the converter or inverter/charger, whichever it is you have.
If that doesn't solve the problem either, then cleck back in and someone who knows better than me will chime in with the next step.
On edit: Looks like someone already has!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-18-2013, 11:17 AM   #4
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
On the early 70 models there were fuses on the battery cables . a fuse for both neg and positive. On later models they put the fuses in the fuse box.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
12v
