Old 05-21-2007, 02:46 PM   #1
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
12V Receptacle
The Wineguard coaxial plate in the front of my International has a 12V receptacle that is of a circumference just too small to accept DC plugs. The outlet in the bedroom fits them fine. My dealer never heard of this problem. AS and Wineguard haven't responded. I'm thinking I got stuck with a mis- manufactured part. Has anyone else had a similar issue?
henw is offline   Reply With Quote
Old 05-21-2007, 02:54 PM   #2
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
henw,
I have never had this problem before...it does sound like a mis- manufactured part.
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 05-21-2007, 05:15 PM   #3
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I have the same setup. Never experienced any problems with the receptacle, but have noticed some 12v plugs are larger than others.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 05-21-2007, 06:07 PM   #4
Naples , Florida
There IS sopposed to be a standard for 12 VDC plugs, but due to the rash of Chinese products and their lack of uniformity (and quality), you got what you got!
There are a couple of other styles and sizes of 12VDC plugs, but the one you have should be the 'standard' automotive type. I would take it up with your dealer and Airstream. It's an easy change-out!
lewster
Old 05-21-2007, 06:32 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
When it comes to a Dealer and a new rig don't ask them if they have heard of a problem just ask them to show you how it works. If they have a problem then they will know about the problem.
2004 Excursion 4x4
Old 05-21-2007, 08:02 PM   #6
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
HenW.
I also ran into the same problem. Please read the following:
Hope this helps a little.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 05-22-2007, 03:57 AM   #7
Cyclist
henw's Avatar
Thanks for the feedback all, and, crazylev. I'll copy your message and show it to the dealer when I go for warranty work.
Tom
Old 05-22-2007, 05:18 PM   #8
cammur's Avatar
Roseville , California
I have the same problem on my 2005. I've ignored it and plugged-in elsewhere, but I did wonder if it was related to the amp limit on that outlet vs the others (see the label on the switchplate). Sort of like different size gas nozzles for different fuel types. Never asked the dealer, but should have.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 05-22-2007, 05:28 PM   #9
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
We had that problem too with the 2005 AS. At the factory I had them switch the smaller one in the bedroom to the same larger one in the front. However the only one they had was with the booster and said the booster part on that receptacle would not be functional. Until they did that switch we used a splitter(one 12volt plug into two plugs) just because that fit and would accept our 12volt appliance plugs-some were ok some were not.
Does anyone know if a 12 volt 12 amp or greater receptacle can be added and where to find one that size? I would like to buy The Wavebox microwave and it needs 12 amps or better. What is the rating of the 12 volt plugs? 8 amps?
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 05-22-2007, 05:40 PM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
carol
mine has a 7.5 amp fuse in it.
hope that helps.
and yes all plugs fit into it.
john
Old 05-22-2007, 07:34 PM   #11
Naples , Florida
Carol,
Some 12VDC plugs are rated to 15 amps. it depends on the construction and of course, the wiring up to it. 14guage MINIMUM! I prefer to use 12 AWG on most of my power wiring. Marinco makes their 'Park Power' models that are 3-4X as expensive as the rest, but THEY ARE WORTH IT!!!! You also might check out Powerlet. They manufacture high quality water-proof components that you'll find in marine applications and also on a lot of motorcycles.
lewster
Old 05-22-2007, 07:48 PM   #12
Lapeer , Michigan
Thanks John, guess the Airstream would not run that microwave on the existing outlets. I think that new lunch box micro is just the neatest thing, however I don't think I will be hooking it directly to the batteries, perhaps I could use it in the truck outlet. If we have elctricity than it hooks up to that. But I thought on the road without a generator or on a picnic table it would be so cool to have it, (especially since our AS does not have one.)
Thanks Lew I will check out those companies you mentioned. I don't think Brad is going to want to run wiring though, from where would you run it, the batteries, can't tap in anywhere right? and where would you run it in? Is this a job any rv work shop could handle and is it a big job?
Caroljb
photography
Old 05-22-2007, 08:59 PM   #13
Naples , Florida
Carol,
I would check out the nearest outlet. Airstream just might have used the bigger guage wire and you just have to replace the socket....you never know!
lewster
Old 05-22-2007, 09:24 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
More good information from the forum.
Hi, I haven't even thought of useing my 12 volt plugs yet; Good to know in advance that they might not work if and when I want to use them. Something else to check next time I pull my trailer out.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline   Reply With Quote
Old 06-01-2007, 09:02 AM   #15
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Our Wineguard socket is too tight also. I tried to plug in a small fan and the fan's plug got stuck in the socket. The plug came apart when I tried to get it out and I had to carefully drill out the wreckage. The fan plugged in fine in the bedroom socket, at least before I destroyed it.
Randy
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
SilverCabin is offline   Reply With Quote
Old 06-01-2007, 09:12 AM   #16
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
My Wineguard is also that way, much tighter than other 12 volt outlets. I keep a dual outlet extension plugged into it. This solves the tightness problem and gives me another 12 volt outlet which I can always use.
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 11-29-2017, 09:02 AM   #17
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
My Winegard 12v/Booster 12v plug was too tight for several of my DC plugs as originally installed during manufacture in 2007. I replaced it with a new version 7042. The 12v socket is now slightly larger and all my DC plugs fit.
Kelvin
2008 Classic 25fb "Silver Mistress"
2015 Ram 2500 6.7L Cummins. Crew Cab, 4x4, Silver
KJRitchie is offline   Reply With Quote
12v
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 07:19 AM
12v vs 120 jane babinski Electrical - Systems, Generators, Batteries & Solar 13 09-30-2002 09:23 AM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 01:14 PM
essential tools maznblu On The Road... 14 07-08-2002 02:23 PM
12V trouble.... Chuck Electrical - Systems, Generators, Batteries & Solar 8 07-06-2002 04:57 AM
